 Peerless 700 stuck in first gear
Jim Jones
Peerless 700 stuck in first gear Empty
PostSubject: Peerless 700 stuck in first gear   Peerless 700 stuck in first gear Icon_minitimeJune 19th 2016, 12:40 pm
Dose anyone know what could be causing a peerless 700 to be stuck in first?
PostSubject: Re: Peerless 700 stuck in first gear   Peerless 700 stuck in first gear Icon_minitimeJune 19th 2016, 12:49 pm
I don't really know much about the 700 but there is most likely rust/corrosion on the shift shaft which stops it moving between gears Wink
PostSubject: Re: Peerless 700 stuck in first gear   Peerless 700 stuck in first gear Icon_minitimeJune 19th 2016, 9:21 pm
Is there a linkage issue your not noticing or maybe shift keys are damaged inside.
Jim Jones
PostSubject: Re: Peerless 700 stuck in first gear   Peerless 700 stuck in first gear Icon_minitimeJune 19th 2016, 9:35 pm
Thank you for the advice i will check out the linkage
» transaxle stuck in third gear
» Peerless 930 stuck in 4th and 5th
» peerless mst206 2nd gear and reverse not workin
» How do you remove stuck rear wheel hubs?
» stuck pulley
