| stuck pulley | |
greener179 Member
| Subject: stuck pulley January 16th 2013, 2:09 am | |
| Im trying to get the pulley off my transmission and it just wont come off any ideas? | |
| | | Doug Site Owner
Age : 29 Join date : 2012-12-24 Points : 7784 Posts : 3047 Location : Lebanon County, PA
| Subject: Re: stuck pulley January 16th 2013, 4:40 am | |
| You can bring it into an auto shop to have them use a puller to yank it off.
Other things you can try is soaking around the shaft in PB Blaster and let it soak in for a few days and try yanking it off again.
If you have the access, you can also use an acetylene torch to heat up the area round the input shaft and shock it with ice cold water. The shock should free the rust. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | greener179 Member
| Subject: Re: stuck pulley January 16th 2013, 10:08 am | |
| Well im going to buy a 6 inch pulley puller tonight i hope its big enough if not i make have to trim the pulley a bit. | |
| | | theswampmachine Member
| Subject: Re: stuck pulley January 16th 2013, 10:18 am | |
| What I do is get an air hammer and carefully hit the top of the shaft making sure not to mess up the threads and pry up on the pulled at the same time. It almost always works for me | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| | | | greener179 Member
| Subject: Re: stuck pulley January 16th 2013, 3:48 pm | |
| sorry about that everyone guess i was in a hurry and didnt realize the thread under mine was the same thing. | |
| | | Marines2621 Member
Age : 27 Join date : 2012-12-31 Points : 4585 Posts : 215 Location : Mountainburg, Arkansas
| Subject: Re: stuck pulley January 16th 2013, 4:13 pm | |
| i cut my pulley off the shaft. lol but the trans is messed up. Thinking about junking it and getting another and rig it. | |
| | | greener179 Member
| Subject: Re: stuck pulley January 16th 2013, 4:20 pm | |
| ya i dont want to mess mine up because its a pearless 700 | |
| | | greener179 Member
| Subject: Re: stuck pulley January 17th 2013, 5:43 pm | |
| Well went outside today my friend had be working on getting the pulley off and i looked he ended up breaking the case. | |
| | | gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5208 Posts : 392 Location : west chazy ny
| Subject: Re: stuck pulley January 17th 2013, 8:55 pm | |
| did he brake the top case? u might be able to get a used top case off ebay or something or if its a small crack have someone who can weld alluminium weld it. | |
| | | greener179 Member
| Subject: Re: stuck pulley January 18th 2013, 1:53 am | |
| the red line is were its broke off | |
| | | | | stuck pulley | |
| Who is online? | In total there are 43 users online :: 0 Registered, 0 Hidden and 43 Guests
