 Grease or Gear oil
Offroader97
Grease or Gear oil Empty
PostSubject: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 21st 2012, 4:23 pm
I have a question I have always had grease in my transaxles but is gear oil better? what should I run this will be for mud. Transaxle is a mst-205-544c comes stock with gear oil and I will have a 25hp V-twin ohv briggs with some 20X10.0-8 4 PLY SUPER LUG carlisle. if I should run gear oil what should I use?
Thanks,
Russ!
Offroader97
PostSubject: Re: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 22nd 2012, 8:11 pm
lol no one?
dagr8tim
dagr8tim
PostSubject: Re: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 22nd 2012, 10:01 pm
Something along the lines of 80w90, 75w90, or 75w140n depending on where you live and how cold it gets.
http://buckeyejeeps.com
Offroader97
PostSubject: Re: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 23rd 2012, 2:18 pm
Florida ....
PostSubject: Re: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 23rd 2012, 5:00 pm
For what its worth, we run gear oil in all of our racing machines' trannys. I believe 80w. It serves well enough whether we are blasting through snow drifts or screaming along in the 90+ degree heat. I don't think any failures we have had were due to the oil.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
Offroader97
PostSubject: Re: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 23rd 2012, 5:17 pm
Should I put a vent on it?
PostSubject: Re: Grease or Gear oil   Grease or Gear oil Icon_minitimeMay 24th 2012, 9:20 am
We do... I guess it depends on how hot you're going to get the transmission and how offensive you find oil seeping out of the various seals etc.
Chaos Build
Haspin 2021 thread
Grease or Gear oil
» witch is best for a 1998 craftsman lt 1000 grease or gear oil
» How do you grease a transmission if there is no grease nipple?
» grease or oil?
» grease to oil conversion?
» Transaxle oil/grease
