 grease to oil conversion?
AcreFarm
Chopperhed
Tuffy55
8 posters
Tuffy55
grease to oil conversion? Empty
PostSubject: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 8:17 pm
i own a dana 6 speed transaxle i was thinking about converting it to hold oil instead of grease
would i need a breather tube?
also if you guys have any other tips please let me know thanks!
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 8:24 pm
My peerless doesnt have a breather and its oil.
Youll need a waterproof oil filler hole. About it.
Tuffy55
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 8:33 pm
ya think its a good idea to convert it?
how much money do ya think it would cost to convert?
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 8:47 pm
Oil filled transmissions should have a vent. All automotive, commercial, and industrial drive lines are vented.
Since oiled transmissions requires some airspace to alow for expansion, you need one.
If you heat the oil too much, and the resulting air pressure has no where to go it will blow out one of your seals.
If you decide to vent it, follow a trick from the full size off roaders, and run a hose as high as you can on the tractor and leave the opening facing down.
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 8:54 pm
Should I incorporate a vent into my Peerless then, especially since I have a 2:1 ratio?
AcreFarm
AcreFarm
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 8:57 pm
If you're going to use oil it will need a vent.
I'd recommend replacing the old bentonite grease with 00 grease instead of oil. 00 will not leak and seep out like gear oil does (it's nearly impossible to keep oil in a transaxle that was built to use grease).
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:12 pm
Agreed,
A proper conversion to oil would involve adding seals, vent etc.
Tuffy55
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:19 pm
so does the 00 grease not whip of the gears like regular grease or what? that whining noise pisses me off so i am constantly adding grease
i have a 4 1/2 front pulley and 3 1/2 rear
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:24 pm
It would be a good idea.
As a side note. I do know of one transmission that is not vented.
Marine outboards, and I/Os have sealed gearboxes, but they are designed to hold pressure. The seals are designed to handle pressure from both sides.
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:26 pm
There are some very exoensive synthetic greases that are very sticky, I used some in a 4x4 diff with a broken pinion tooth, and it shut the whine up a bit. Problem is, its very pricey, and usuallly only available in 5 gallon buckets or 45 gallon drums. You can get it in a 16 oz tube but the extra fillers added change the characteristics.
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:33 pm
Now the joys of trying to figure out how to do it. Would have been easier to drill and tap a hole when it was apart.
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:36 pm
If you didn't add any seals it will vent on its own out the axle shafts., How much oil is in it?
Tuffy55
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:42 pm
if i get any kind of synthetic grease would it stick better than some multi purpose cheapo stuff?
also does the grease in there turn into oil because of the heat and friction or what? it seems like if i keep adding grease there would be so much in there that there would be no room for the grease to fly off ya know?
thanks for the help
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:43 pm
I used gasket sealer on the metal mating surfaces but I didnt go around the seals.
Not sure really. I used what I had in my bottle and it was a little under 2/3 full but not 1/2. Its not filled to spec thats for sure.
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:48 pm
thanks for the help
Synthetic may be stickier,
the stuff I was using was designed to stick under high pressure, while being exposed to hydrogen sulfide. I was using Lubchem Valve grease.
Yes grease will get thin under pressure and heat. when you are too full it will find a way out somewhere.
Oil filled units are usually built o be a miximum of 60% or so full, to allow room for expansion.
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:51 pm
You should only fill to about 60% anyways. Depending on what you used for oil, it will make its way out through theaxle bushings if it needs to.
Tuffy55
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 9:54 pm
ok thanks i might just try pumping in some synthetic grease
sorry to hear about your dog copperhead thats ruff
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 10:22 pm
Most my mod transmissions whine, basically because they were designed for 5mph instead of 20 plus mph - way they were cut at the factory .
I ran half a case full of nothing but plain lucas oil engine oil additive in the trans on my mod murray, it whined terrible still, but it held together with no issues.
In both my stock and one mod MTD, i drilled and tapped a zerk fitting in the bottom of the transaxles, to slap some fresh lucas oil grease into them every so often.
As long as the zerk doesnt interfere with any internal parts, they can be put pretty much anywhere accessable.
Chopperhed
Chopperhed
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 8th 2013, 10:43 pm
She's special to me. I rescued her 7 years ago, when some guy was going to have her put down for a little ankle injury
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 9th 2013, 8:33 am
I've converted all my peerless transaxles to gear oil. Installed a breather, drain plug, cut brake shaft off and ran capped bearing, installed grease zerks on the axle. Here's a video, covers some of it. It doesn't leak any now, but you have seal and grease the axle correctly. When it did leak, it wasn't much.
Tuffy55
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 9th 2013, 12:18 pm
i do have 2 grease zerks on my transaxle which does make adding grease way easier.
Ill probably get a new transaxle this spring 600 series or 820 if i can find one. my dana transaxle just sucks all the bushings are gone and it is not very reliable. Bushings cost so much to i might just say screw it and romp it till it breaks.
or should i replace the bushings and convert it to oil filled?
I HATE SPENDING MONEY
Murray modder
Murray modder
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 9th 2013, 2:07 pm
If your trying to take the whine away, I use automation transmission fluid I found in the back of my shop! mine doesnt wine all to much, but it seems good.
craftworks125
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 10th 2013, 1:00 am
Cheap ass lol!
Tuffy55
PostSubject: Re: grease to oil conversion?   grease to oil conversion? Icon_minitimeFebruary 10th 2013, 6:14 pm
hahahahaha got that right
» How do you grease a transmission if there is no grease nipple?
» grease or oil?
» Transaxle oil/grease
» What type of grease?
» Grease or Gear oil
