| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 9:39 am | |
| Suspension is looking incredible red. Those gusset tubes down to the front spindles are sweet it should be plenty strong. You will love this set up. | |
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 10:24 am | |
| - Thunderdivine wrote:
- Awesome mod Red!
And it's like you have your own waterjet allready, with all that metal and available parts.
So won't the steering link limit the flex some too? the tie rod thing? Yea, I need to love it up to prevent damage because it's low laying. I'll have to move the trac bar frame mount up a hair. I'm trying to make sure everything clears without bump stops in case one rips off or something - Rarbaugh07 wrote:
- Suspension is looking incredible red. Those gusset tubes down to the front spindles are sweet it should be plenty strong. You will love this set up.
Thanks man, I give full credit to you. It's pretty simple and cheap, vs a triangulated 4 link. I'm wondering about shocks, like maybe old kinda worn out vehical shocks. Something small, strong, and long length. | |
ZSmachines Member
Age : 25 Join date : 2014-08-27 Points : 3992 Posts : 221 Location : PNW
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 12:34 pm | |
| Since you already have cool front suspension, mabye you could switch from a transaxle to a peerless 700 and run the rear swing arm from a quad! Now that would be cool!! | |
rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4077 Posts : 117 Location : Logan, iowa
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 12:39 pm | |
| Small car shocks will work just getting enough stroke might be tough. If you mount them inboard far enough or even part way up your link bars would give you enough travel with a shorter shock. Best part is you can weld/cut steel until it works just right. | |
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 1:36 pm | |
| - ZSmachines wrote:
- Since you already have cool front suspension, mabye you could switch from a transaxle to a peerless 700 and run the rear swing arm from a quad! Now that would be cool!!
To much that can break. A 820 well, doesn't break. - rarbaugh07 wrote:
- Small car shocks will work just getting enough stroke might be tough. If you mount them inboard far enough or even part way up your link bars would give you enough travel with a shorter shock. Best part is you can weld/cut steel until it works just right.
I didn't want to use car shocks but I thought the stroke was long enough, I don't really know. I'll find out sooner or later. | |
Thunderdivine Veteran Member
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 2:26 pm | |
- I would use whatever shocks you have, and mount em with bellcrank's. That way you can gear it. sounds complicated but it's not. Kinda like a F1 mount. You can hide them if you wanted too, and still have 10 inch of travel
Now this is a good idea. Never thought of doing that. | |
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4171 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 4:18 pm | |
| - Carshowkid wrote:
- ... And y'all lost way far back in this convo... With bell crank and dirt bikes...
This is a bell crank. as the suspention travels up, it rocks the rocker and compresses the coil over. Im looking at more of a simple setup then that though. so im still looking around. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 4:37 pm | |
| I've thought of that but have shocks on both sides of the bell crank for more travel. | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 4:54 pm | |
Im looking at more of a simple setup then that though. so im still looking around. thanks red for explaining that to me! | |
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 6:42 pm | |
- A Better example would be:
I saw that but figured he wouldn't know where the push tubes connected to. | |
Doc Sprocket Site VIP
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 7:34 pm | |
| Thunder's right... Thanks to te principles of the bellcrank, you can use nearly ANY coilover you can find, and alter effective spring rate to suit. | |
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 7:37 pm | |
| - Doc Sprocket wrote:
- Thunder's right... Thanks to te principles of the bellcrank, you can use nearly ANY coilove you can find, and alter effective spring rate to suit.
I think hes talking about just the shocks. sure you could mount some coil overs in there. im not sure how i'd like that deal tho, means id need to have a pivot arm with bearings/bushings, and another thing to maintain. Not shooting it down at all, just not what i was thinking about. | |
| Subject: Re: MTD off-road romper build. Wed Nov 19, 2014 8:08 pm | |
| Springs, shocks, whatever. The ability to adjust the leverage applies. No, it may not be practical for you, but a great idea nonetheless. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Thu Nov 20, 2014 8:46 pm | |
| Biggest problem I see happening is your mower will want to just tip on a side hill until your limit straps pull tight. And then dumps you off the seat. Even mine does this somewhat. | |
| Subject: Re: MTD off-road romper build. Thu Nov 20, 2014 9:07 pm | |
| - rarbaugh07 wrote:
- Biggest problem I see happening is your mower will want to just tip on a side hill until your limit straps pull tight. And then dumps you off the seat. Even mine does this somewhat.
So like a frame twist? or chassis roll, just gravity version. lol, i could see that happening. so maybe a snowmobile sway bar in the mix? not sure how much those twist though. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Thu Nov 20, 2014 9:19 pm | |
| Not frame twist, chassis roll. A swaybar would be ideal and maybe having levers with multiple holes on the sway bar for different rates and adjustability. Snowmobile one or ATV one should be about perfect. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Thu Nov 20, 2014 9:21 pm | |
| - rarbaugh07 wrote:
- Not frame twist, chassis roll. A swaybar would be ideal and maybe having levers with multiple holes on the sway bar for different rates and adjustability. Snowmobile one or ATV one should be about perfect.
Do you get any torque roll at all? And how much travel does the rear get? | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Thu Nov 20, 2014 9:30 pm | |
| Actually no torque roll but only got a built 5hp flatty. Probably 4-5 inches straight up and down and 7-8 articulating at the wheel. | |
| Subject: Re: MTD off-road romper build. Thu Nov 20, 2014 9:48 pm | |
| What about making up your own shocks? Assuming you use those coil springs that you already have, you could make some oil filled knee action shocks or friction shocks. No they might not look as cool as finding regular shocks somewhere, but you could make them pretty compact and bolt on. Then you could easily remove them later if you wanted to change it. Could make something with an adjustable dampening. Like a small oil filled box with a paddle inside attached to a lever. Could have an adjustable bypass or something. I don't see how you will be able to get a lot of flex out of it if your trying to have only a few inches of travel. What I mean is, if the frame is going to sit up off the axle normally at about 2" or whatever, is there much advantage to the wheels being able to drop much more than a few inches below where it normally sits? That kind of decides how much stroke and everything you need out of your shocks I guess. | |
rarbaugh07 Member
| Subject: Re: MTD off-road romper build. Fri Nov 21, 2014 6:04 am | |
| I found my old truck shocks that could work. Accept, pushing in it's pretty easy. Pulling out it does it very slowly no matter the force. I was thinking about modding the bypass so it stiffer, but I have no clue how to or is grinding/welding shocks back together is safe... | |
