| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
Thunderdivine Veteran Member
| Subject: Re: MTD off-road romper build. November 16th 2014, 5:10 pm | |
| What welder did you use for that thick metal? Looks good. - and show us a plan of this secret suspension thingy, kinda looks like what i would build if i had the room for a mudder. | |
| Subject: Re: MTD off-road romper build. November 16th 2014, 10:49 pm | |
| - Thunderdivine wrote:
- What welder did you use for that thick metal? Looks good. - and show us a plan of this secret suspension thingy, kinda looks like what i would build if i had the room for a mudder.
My Hobart handler 140 set up for MIG. It welds like absolute butter, 1/4" melts right in. | |
| Subject: Re: MTD off-road romper build. November 17th 2014, 10:45 am | |
My Hobart handler 140 set up for MIG. It welds like absolute butter, 1/4" melts right in. Then it's a good mowchine. None of my cheap ones could penetrate the 1/4" or thicker steel. | |
| Subject: Re: MTD off-road romper build. November 17th 2014, 11:09 am | |
My Hobart handler 140 set up for MIG. It welds like absolute butter, 1/4" melts right in. Then it's a good mowchine. None of my cheap ones could penetrate the 1/4" or thicker steel. Yea people say the harbor freight 90 amps can weld 1/4, and I had a 90 amp, not Hf, but still didn't penetrate for crap. I literally broke the leaf spring mounts that were 1/4" welded onto the frame off with a big cresant wrench in the tear down video. | |
| Subject: Re: MTD off-road romper build. November 17th 2014, 11:14 am | |
My Hobart handler 140 set up for MIG. It welds like absolute butter, 1/4" melts right in. Then it's a good mowchine. None of my cheap ones could penetrate the 1/4" or thicker steel. Yea people say the harbor freight 90 amps can weld 1/4, and I had a 90 amp, not Hf, but still didn't penetrate for crap. I literally broke the leaf spring mounts that were 1/4" welded onto the frame off with a big cresant wrench in the tear down video. Did you chamfer the edges before you lay the beads down? And maybe a pre-heat will help the harbour freight people. | |
| Subject: Re: MTD off-road romper build. November 17th 2014, 9:55 pm | |
My Hobart handler 140 set up for MIG. It welds like absolute butter, 1/4" melts right in. Then it's a good mowchine. None of my cheap ones could penetrate the 1/4" or thicker steel. Yea people say the harbor freight 90 amps can weld 1/4, and I had a 90 amp, not Hf, but still didn't penetrate for crap. I literally broke the leaf spring mounts that were 1/4" welded onto the frame off with a big cresant wrench in the tear down video. Did you chamfer the edges before you lay the beads down? And maybe a pre-heat will help the harbour freight people. Yea, on the 1/4" stuff grinding the endge down helps a good amount. Lots of stuff from this weekend and yesterday. Make the link mount to the uniball, 1/4" tabs and angle iron, spacers to decrease walking. Roughly 30 degrees of pivot. In the meantime, i took the rear tires off, cut and grinded the old hubs out. Gurk, what a fiasco. Cut the sides off the new axle rims and welded the center disk on. 4x4" hubs. With the tires now on, I centered the axle, determined ride height and cut out some links. Put 5 degrees of caster on the front axle, i hear it helps out with turning with a posi rear end. Beef trac-bar. Taking advantage of that old hydro steering ram mount. And frame mount. Now what people have waited for. About 17" of max flex on each side. Obviously not going to have that much, but is cool to look at. Might have to move the trac-bar mount for a little more clearance for when i move the tie rod up. Also did a second tube support for more......support. notching tube with a grinder really doesnt work to well, but eh, i got within 1/8" gap. Good enough. All of this looks about 100x easier then it actually was lol. this is about 2 1/2 days of working. | |
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4171 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: MTD off-road romper build. November 18th 2014, 11:13 am | |
| - Carshowkid wrote:
- HOLY FLEX!!!
Thanks, some limit straps are in order or else the coils will fall out. | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. November 18th 2014, 12:42 pm | |
- Carshowkid wrote:
- HOLY FLEX!!!
Thanks, some limit straps are in order or else the coils will fall out. yeah limit straps are first thing on the list | |
1997 Murray Veteran Member
ZSmachines Member
Age : 25 Join date : 2014-08-27 Points : 3992 Posts : 221 Location : PNW
| Subject: Re: MTD off-road romper build. November 18th 2014, 6:14 pm | |
| That looks sweet!! I hope to be able to have that much flex by cutting eyebrows on the axle and a small bit of frame on my craftsman! So, how did you add the caster? | |
| Subject: Re: MTD off-road romper build. November 18th 2014, 6:49 pm | |
| Thanks guys.
ZSmachines, caster is just tilting the axle backwards. so, before i welded the links up, i angled the axle back about 5-4 degrees. you can do this with yours if the axle plate that sandwiches the axle beam is bolt on, you can just bend it out and brace it. | |
ZSmachines Member
| Subject: Re: MTD off-road romper build. November 18th 2014, 7:12 pm | |
| - ZSmachines wrote:
- Ok thanks! Now IN theory the axle itself could be heated and bent?
The axle beam has to be tilted, and no, tilt the brackets that hold the axle to the frame and weld or re bolt them | |
ZSmachines Member
| Subject: Re: MTD off-road romper build. November 18th 2014, 7:37 pm | |
| Oh I just reread my comment and when I said bent, I ment twist. So essentially you are doing the same thing as bending the mounts, but you still have a true up and down motion as it did stock. | |
| Subject: Re: MTD off-road romper build. November 18th 2014, 8:45 pm | |
| - LAWN MOWER MUDDER wrote:
- Will she be ready for haspin next year?
Im on track to be ready in under a month i figure. not sure, i might have to wait till Christmas so i can get the disk brake on. (gift im thinking of) Haspin? Its a long shot. i think my graduation is the 24th or 26th, something like that. so tests and junk are that weekend. ill see, but as i said, not very good chances like usual.
Last edited by redlinemotorsportts on January 10th 2015, 2:51 pm; edited 1 time in total | |
jamcco Member
Age : 25 Join date : 2014-01-04 Points : 4216 Posts : 226 Location : New Hampshire
| Subject: Re: MTD off-road romper build. November 18th 2014, 8:49 pm | |
| Looks good, I like the mono link...suspension is probably my favorite thing to mess with so far | |
| Subject: Re: MTD off-road romper build. November 18th 2014, 8:50 pm | |
| - jamcco wrote:
- Looks good, I like the mono link...suspension is probably my favorite thing to mess with so far
Suspension is #1 most favorite, and exhaust is a close second. Paint third? LOL | |
Doc Sprocket Site VIP
| Subject: Re: MTD off-road romper build. November 18th 2014, 10:17 pm | |
| - Doc Sprocket wrote:
- Your front end is looking really good, Red. Nice work!
Thanks! Hopefully it doesnt break, or bend for that matter. | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. November 18th 2014, 10:18 pm | |
Thanks! Hopefully it doesnt break, or bend for that matter. if it breaks... Just means you didn't build it strong enough... Or romped it too hard | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. November 18th 2014, 10:21 pm | |
Haspin? Its a long shot. i think my graduation is the 24th or 26rd, something like that. so tests and junk are that weekend. ill see, but as i said, not very good chances like usual.
if I may ask what's haspin? | |
| Subject: Re: MTD off-road romper build. November 19th 2014, 8:45 am | |
| Awesome mod Red!
And it's like you have your own waterjet allready, with all that metal and available parts.
So won't the steering link limit the flex some too? | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
| Subject: Re: MTD off-road romper build. November 19th 2014, 9:30 am | |
if I may ask what's haspin? Only the best offroad lawn tractor rally ever . I just posted the event for this year in the community networking > events area. | |
rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4077 Posts : 117 Location : Logan, iowa
| Subject: Re: MTD off-road romper build. November 19th 2014, 10:39 am | |
| Suspension is looking incredible red. Those gusset tubes down to the front spindles are sweet it should be plenty strong. You will love this set up. | |
