 BIG T's first off road build
BIGT
7 posters
BIGT
BIGT
BIG T's first off road build Empty
PostSubject: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 7th 2017, 9:09 pm
I figured id start my first build so i  have  90's ford yt16h its got 16hp kohler twin and a hydro rear
plans for it would be to lift in to fit 27" mud zilla tires swap out the hydro and add bumpers winch rack extra lights
im open to ideas and such and i will post pics sometime tomorrow if i can find it after the snowstorm i might do a youtube build series on it as well for you guys to see whats going on other than just the pictures im very open to ideas of what to do and such i may not use all of the suggestions but i will try and use as many as possible
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 10:49 am
They are pretty decent sized tractors aren't they? Can't wait to see pics!
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 1:01 pm
BIG T's first off road build 205b6910
heres basically what im starting with and yes i got that pic off google but mine looks pretty well identical
ive started looking for parts the biggest thing is gonna be finding the peerless 820 transaxle and swapping everything over from hydro to geared
my plans for this tractor will be:
dual throttle
27" mudzilla rear tires
different front tires (i have no idea on them)
bumper
rack
storage
winch
lights
better trailer hitch
charging system
air compressor and quick disconnect booster cables
Im open to everyones ideas and suggestions just post a reply
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 1:12 pm
Should be cool! When you say dual throttle, do you mean hand and foot throttle? That's what I'm planning on adding to mine as well.
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 1:26 pm
yeah foot throttle and the dash for long adventures
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 2:05 pm
Carlisle snow hogs and X-tracs are pretty commonly run on the front. Fearless runs the snow hogs and redneckcomputergeek runs the x-tracs. I still haven't decided between the two lol
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 2:09 pm
at the same time i also want this build to stand out and do stuff that no one has done before on a off road build
tater195
tater195
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 3:29 pm
The YT16s with the gear tx were prone to snapping axles. They had 23" tires on 12" wheels and 3/4" axles. They were not a bad mower, but using them for anything other than that was asking for trouble. You can overdrive the hydro a little. With the 27s and a mild pulley swap you should be able to get it in the 10mph range.
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 5:01 pm
it all depends on how you build it too and for speed wise im looking to get between 20 and 30km/h
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 5:24 pm
On the charging system, maybe a 10/12 SI GM alternator . The original 10 SI can go up to 63 amps (steel fan), while the original 12 SI alternator goes up to 94 amps (plastic fan). With a volt gauge and dummy light in the dash. Pretty easy and reliable setup.
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 7:14 pm
where would be the best place to mount it as this tractor may see some mud on the trails and such
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 10th 2017, 9:11 pm
Looks like a vertical shaft engine. Maybe mount a pulley on top of the engine, centering would be mandatory though, like a home made pull start setup, to drive the alternator. Then make a bracket to hold alternator in front of motor. In engine compartment away from any mud.
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 11th 2017, 10:53 am
Just axles?
BIG T's first off road build Img_2111
BIG T's first off road build Img_2112
lol!
I dont know how the hydro trans compares to this, but an axle truss might not be a bad idea if it has the long axles like this one.
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 11th 2017, 2:14 pm
Cool! Make sure to post lots of pictures of that.
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 11th 2017, 11:38 pm
To the transaxle breakage it's probs because you had a Spicer in there I'm trying to find a peerless 820 transaxle and I do plan on adding lots support in that area and skid plate for sure only because it will take lots of abuse and I will take pics when I do the dual throttle
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 12th 2017, 10:00 am
That particular spicer is identical to a peerless... not sure what one though.
The rig was free anyway. Woot.
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeJanuary 12th 2017, 1:46 pm
Yeah the one that's in mine is a hydro and it's got the 1 inch axles just like the peerless 820 so I'm hoping that will be heavy duty enough
BIGT
BIGT
PostSubject: Re: BIG T's first off road build   BIG T's first off road build Icon_minitimeApril 13th 2017, 2:15 pm
Just a lil update I finally decided to pull it out and do an lil bit of work to it I'm currently working on pulling turf savers 20 10 8 on the front with a mild lift and got rid of all the hydro setup and I finally found a peerless 820 transaxle already locked and greased
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
» Off Road Noma Build
» Allis 716 Off-Road Build
» MTD off-road romper build.
