 Off Road Noma Build
rynomine
8 posters
Go to page : 1, 2, 3, 4, 5, 6  Next
rynomine
rynomine
Off Road Noma Build Empty
PostSubject: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:35 pm
This is the build thread so whoever was commenting before. Please say stuff here. Thanks.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:44 pm
You doing a normal take your time build or did you want to enter the buildoff?
Off Road Noma Build Sig115PROJECTS:
Off Road Noma Build Sig214Off Road Noma Build Sig314
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:45 pm
@mightyraze Enter the Buildoff!
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:47 pm
If I hadn't had the motor rebuilt in Ol Red I would'f spend about $600. That's a good size budget to work with, but you can do a lot for less.
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:49 pm
ok.
Anyway, if you are gonna buy a new carb you could also put a wide bore carb on, then it'll really rev here up!
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:51 pm
Agreed, $600 is a great budget! Hell I built my rat rod tractor for $58.06, and most of that was a belt, haha.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 8:52 pm
Minus tire, Nellybelle was $50, with tire 200 but I went with really expensive ones.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 18th 2018, 9:29 pm
@rynomine  Top right is the Buildoff Instructions...  Get 'er done!
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 10:38 am
Ok!
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 1:50 pm
Update~~~~ So I found a Motor I could use if the one in mine doesn’t work.
Off Road Noma Build 15190610
It’s 250 bucks.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 2:24 pm
I think that’s a little too much money to be spending on a used motor.
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 2:26 pm
K
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 3:01 pm
I agree with Carl, you could buy a tractor that has a rotting deck for like $50 and scrap it and steal the engine.  Especially since that on is a Kohler engine.
But at the very worst, a new filter, shut off valve, fuel line, fuel pump, and carb is less than $45.  How many HP is the engine it has right now?  You only need 10 hp, anything else is overkill.  Nothing wrong with overkill, but I would not go out of my way to do it.
rynomine
rynomine
PostSubject: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 3:38 pm
Hi everyone I’ve decided since I want to have fun on my first build and I want to do it right. And of course I don’t want to rush the build. I am going to not enter the build off and just do it at my own pace. Now I will still document it with videos and posts. But I think I will have a much better first experience doing it this way. And I will have time to make more money. So I can make the tractor really cool.
So here are my plans.
My base tractor is a“Noma Model F315-000”
The starting upgrades I will do to it are some new tires with good tread.
The next thing I will do is install a tethered kill switch, and a hand or foot throttle. I still haven’t completely decided.
And of course get the engine running.
If you guys have any suggestions on what I should not do or do. Please tell me below.
Also, it is a 15.5 hp
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:10 pm
.PULLEY SWAP!!!!!
Also, yeah 15.5 HP is plenty.
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:12 pm
Oh I was already planning to do a pulley swap. I just forgot to put that on the list.
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:14 pm
Also does anyone know how to use a horizontal shaft engine in a vertical shaft application. Because if this motor doesn’t work. Or I get a new one because every time my friend got it running it would need something new. If I get a new one I will get a predator.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:24 pm
If you were to do that you could run engine with the crank parallel to the frame, have the belt drop down through the frame, and have mule drive sort of deal with a couple of pulleys to turn the belt *90 to direct it to the transaxle pulley. Not sure exactly how reliable that setup would be, but I'm sure it's possible.
rynomine
rynomine
PostSubject: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:25 pm
Ok I’ll look into that.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:28 pm
I've also wondered if you could just drill new holes in the frame of the tractor, and use the threaded holes in the horizontal that go to the torque converter and use those like a regular engine mount. IDK.
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:32 pm
Well I just found this. I don’t know if this is real though.
http://www.hovercrafter.com/pdf/belt%20drves.pdf
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 4:52 pm
Yeah, that *90 mule drive setup is what I was talking about. That's how most lawn/garden tractor with forward facing horizontal engines run the belt down to the deck pulley.
rynomine
rynomine
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 5:13 pm
I Just read that you will lose about 5 hp if you do a mule drive.
PostSubject: Re: Off Road Noma Build   Off Road Noma Build Icon_minitimeFebruary 19th 2018, 6:14 pm
I really doubt you'll lose that much. Snapper LT16s (and some sister models of that) use a 90* mule drive to drive the deck, and the 16hp oppy will spin a 48* deck at idle. Although That setup has an electric clutch, so there's constant tension. No clutching.
Off Road Noma Build
Page 1 of 6Go to page : 1, 2, 3, 4, 5, 6  Next
» Noma Canadiana Build!
» MTD Off Road Build
» SS-16 OFF-ROAD BUILD
»  Mud Mutt Off Road Build
