| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
Carshowkid Member
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4418 Posts : 315 Location : Florida
| Subject: Re: MTD off-road romper build. February 10th 2015, 4:45 pm | |
- Steel. Angled front and back so I can drag it over stuff. I think the 1/8 - 3/16 plate I have is about as wide as the frame. Little ears on the ends and have like 4 bolts holding it on. Probably wing nuts for easy removal on the trail. The 16ga belly pan will go probably up to the engine crank but still figuring out how to mount it. I think I'll use pins with rubber "washers" should keep brush out if the belts when running in the woods.
yea I have broke belts Becuase of sticks and stuff so for splash protection and belt brakeage protection I think it's a good idea | |
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: MTD off-road romper build. February 10th 2015, 8:45 pm | |
| - Carshowkid wrote:
- Nice list... But new motor? What is wrong with opposed?
Answer is on page 53, keep up! lol | |
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4174 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: MTD off-road romper build. February 11th 2015, 7:53 am | |
Answer is on page 53, keep up! lol butt... Butt!!!! THERE ARE SO MANY TOPICS IM FOLLOWING ON!!!! It's hard to keep up now... And hw at school sucks now... So I have even less time | |
Age : 34 Join date : 2013-11-02 Points : 7172 Posts : 2910 Location : New Jersey USA
| Subject: Re: MTD off-road romper build. February 21st 2015, 9:38 pm | |
| Pressed in valve guide came loose and slid up into the exhaust port. Terrible situation...just terrible. | |
| Subject: Re: MTD off-road romper build. February 28th 2015, 10:33 pm | |
| First of, WOW, its been to F'ing cold for to F'ing long. I cant work in this junk! BUT-today it got to a toasty 22F out so i went and worked on the hubs i left off on. Got a $11 or so bit from advanced auto. went to try it out in our big drill and SNAP! Like a freakin' twig. ****..... lucky i scrounged up another 1/2" bit, and worked, eh alright. I mean it didnt break in half before i could put a dent in my material... Exhibit A that made for interesting shop language: Zipped off the little sleeve on the end so the hubs stick out farther. Got all the holes drilled the ones on the corner are tough. Ran the bolts thru everything and tightened up, didnt weld anything. i cant decide if i can make use of those lugs and make little spacers or what. What ever, this is how it sits now at least. Probably going to get tubes to seat these stupid tires. | |
Age : 23 Join date : 2013-04-08 Points : 5212 Posts : 913 Location : Central Pa
| Subject: Re: MTD off-road romper build. March 1st 2015, 2:11 pm | |
| Hey, if you have anymore of those offset 3-lug hubs for a 1" axle and matching rims (8" tall 6" or so wide), shoot me a pm. | |
| Subject: Re: MTD off-road romper build. March 1st 2015, 4:34 pm | |
| Sorry, there isn't any more in the junkyard, I picked these hubs off a big gt john deere hydro. The hubs are actually off set like 1/4" for some reason too. | |
| Subject: Re: MTD off-road romper build. March 4th 2015, 9:41 pm | |
| I don't know, in that last pic the front end looks a lot wider than the rear. Looks like more than you could get back with spacers. I mean I guess they would help. Not that it really hurts anything anyway. How come anything you have with four wheels has the front tires wider than the rear? I think you've been hanging around with the guys who work at the nissan racing department. So are you gonna go with some wild rim color this time or just stay with black? | |
| Subject: ur a goof March 4th 2015, 10:01 pm | |
| Its all about being able to turn with those big tires man!! And if the front fits in a trail so will the rear... duh | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. March 4th 2015, 10:25 pm | |
| Red this tractor had come so far and all... But those rear Kendra's I think... Look insanely awesome!!! | |
| Subject: Re: MTD off-road romper build. March 4th 2015, 10:37 pm | |
| - Carshowkid wrote:
- Red this tractor had come so far and all... But those rear Kendra's I think... Look insanely awesome!!!
Hopefully it looks better when i groove the knobbys. youll see. I have some more junk ill be able to get done to this, its going to be above freezing for majority of next week! Shop time | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. March 4th 2015, 10:49 pm | |
Hopefully it looks better when i groove the knobbys. youll see. I have some more junk ill be able to get done to this, its going to be above freezing for majority of next week! Shop time lucky!!! You have a shop... I have a drive way whenever it's above 10F ... Until April when we build a garage. But why are you cutting perfectly good knobbies? | |
Carshowkid Member
| Subject: Re: MTD off-road romper build. March 8th 2015, 10:06 pm | |
| Just go out to St. clair pa and get all the free tires you want. Sure you might have to pick through to find good ones. I'm gonna stop out that way monday and get my reading anthracite access permit. I'm gonna check if those 12" atv tires are still where I left them. Need a good spare for the baja sears. I think there was two there, but they weren't exact matching tread. Might be a bit dry rotted by now, it was about a year ago when I saw them. | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5720 Posts : 1402 Location : Central PA
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: MTD off-road romper build. March 9th 2015, 12:26 am | |
Hopefully it looks better when i groove the knobbys. youll see. I have some more junk ill be able to get done to this, its going to be above freezing for majority of next week! Shop time still gonna be juek | |
| Subject: Re: MTD off-road romper build. March 9th 2015, 6:50 am | |
| - TheBeal wrote:
- So tell me... Whats your thread page goal for this?
Page number goal? Oh, I don't have a goal. It just....happens | |
| Subject: Re: MTD off-road romper build. March 9th 2015, 8:56 pm | |
| Ah so more progress from the past week and today. High steer, wanted to get this done. Took the old bar, cut the spindle steer arm ends off, turned the tie rod 180 and flipped it upside down. Gained about 3" of clearance. Im thinking building a bumper almost on the axle that drops down and protects the tie rod when i hit rocks or the tire slips off the rock and ends up inbetween the tires. Tie rod ends are pretty automotive type. have to use a ball joint separator to remove the tie rod. Have grease zerks too. Original setup: Cut and moved them up. Used 1/4" plate. Tie rod really tucked into the rim as much as possible. Excuse the trash welds where I think i can weld over my tack welds Modded the steering stops. Pretty easy. End result. Much better. Onto the Arctic cat brakes. All this time i thought i was putting them on the axle. Silly me, didnt even check if that honkin' 8" rotor would fit, and it didnt... Buy a mile... Plan B (or only other option) imput shaft brake. Maybe this is a first? For vertical shaft trannys at least. Put the rotors hub on a lathe, re faced it, and bored it within thousands to my pulleys shaft. Took a long time of tack weld, spin the pulley and rotor, tap it with a hammer, spin more, tap more, even spun it with a drill. I think i got it within 30 thousands. Aint perfect by any means but its damn good for me. After i was done with that, i mounted the caliper all the way back in the corner. after a bunch of cutting, grinding, close measurements, careful bolt hole drilling, i made a bracket for the caliper. All together. Took a lot longer then pictures say it did, but i feel like it will work good. I put a hole in the side of the frame for the snowmobile brake handle cable. I think ill mount it on the fender to the left of me. Has a parking brake on it too. | |
| Subject: Re: MTD off-road romper build. March 9th 2015, 9:41 pm | |
| Keeps the tie rod up out of the way a lot better. Actually a neat spot for the brakes since it's protected in there from hitting junk or water splashing onto it. Mostly anyway. I'd say rugged enough to put the brakes on the trans when your only going like 20mph max.
rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4080 Posts : 117 Location : Logan, iowa
| Subject: Re: MTD off-road romper build. March 10th 2015, 11:14 pm | |
| Pinion brake only so no brakes in neutral then or also regular brakes? And is it finally warming up in NY cause I can't wait to see that thing out wheelin. | |
| Subject: Re: MTD off-road romper build. March 12th 2015, 2:37 pm | |
| - rarbaugh07 wrote:
- Pinion brake only so no brakes in neutral then or also regular brakes? And is it finally warming up in NY cause I can't wait to see that thing out wheelin.
Yea no Nutrel brakes but I don't think it's a big deal. I DID wheel all last year with no brakes at all. And thanks, close to driving it but don't have to much cash. All in pay pal. | |
MurrayMayhem Member
Age : 25 Join date : 2013-01-03 Points : 4461 Posts : 99 Location : 820 Opposed Twin RD. AxleBreaker City
| Subject: Re: MTD off-road romper build. March 12th 2015, 4:34 pm | |
| thats a great brake idea. It just seems apretty big for the input shaft. I've broke alot of those things by dumping the clutch, lol. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7321 Posts : 2914 Location : Ontario Canada
