 MTD off-road romper build.
ranch king pro 08
Axelsol89
mowerheadder
STUNTMAN JON
Rockinator
WilliesBuilds
98svtcobra
MurrayMayhem
jack9102
802 Customs
untrusty huskee
Carshowkid
rarbaugh07
ZSmachines
Deluxe66
Jerbear0612
Moose
Angchor
B440
jamcco
Craftsman1998
breadtrk
camomanusa
mrkadage
MoWheeler
mzeng100
T-Dub13
GenevaCustoms
muddstir
TroyBilt Pony
cumminsbayou
crazykid1994
xxXMowerdudeXxx
genegillis5
Jamus
MowBandit
1993-Sierra-Z71
motorizedeverything
flamudmower
Murray modder
Chopperhed
Ddwannabe
mudmonkey06
70 posters
Go to page : Previous  1 ... 20 ... 36, 37, 38
MTD off-road romper build. - Page 38 Empty
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 13th 2016, 11:40 pm
Thanks all, and they are fitting in the pockets i made for em in the bumper.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 27th 2016, 12:39 am
Moving onto steering, dropped the front axle and took the auger box out. like i thought one gear was chipped on both the ring and pinion gear.
MTD off-road romper build. - Page 38 13833410
MTD off-road romper build. - Page 38 13664410MTD off-road romper build. - Page 38 13871910
So i went shopping (salvge yard) for a new snow blower pinion gear. I blow a airens snow blower all apart and the gears are also stripped in that case and got me thinking, well i guess these arnt as strong gear boxes as i would think. I set it aside and went to brouse for some new steel u joints to replace my aluminum steering u joints. Two 280z datsuns with no engines sitting next to each other, i took the steel steering u joints off of them, and the non p/s car i looked at the steering rack and reailised its the perfect candidate to modify for my use.  The steering pinion imput shaft is almost 90deg to the housing tube, tube is steel, and no power steering guts so i took it to shorten. I got it home and blew it all apart (pretty easy actually) and began cutting it up and shortening it 10". Started with shortening the long shaft with the chop saw and welding it back together.
MTD off-road romper build. - Page 38 13872510
MTD off-road romper build. - Page 38 13875010
MTD off-road romper build. - Page 38 13867010
Chop the tube and re weld back together with the long shaft in to keep it straight, and your done! did a small bit of filing at the end of the tube to make the shaft slip effortlessly.
MTD off-road romper build. - Page 38 13871710
Torched up some 1/4" plate and bent it for mounts. Went and got some 1 1/2" exhaust clamps to hold it all together. there will be some more gussets from that 1/4" plate to the axle beam to make sure its rock solid.
MTD off-road romper build. - Page 38 13672410
MTD off-road romper build. - Page 38 13872310
chopped the front of the skid plate up a little and took the thin sheet metal skid off, mounted this up. Looks right at home. I actually gain ground clearance with the setup, so im going to modify the skid plate frame a little to get another inch or so of clearance.
MTD off-road romper build. - Page 38 13833010
Reason im replacing the u joint (other than the rack swap) is the aluminum u joint must of not really pinched onto the steering shaft or loosened up, causing it to just waller out the bore and wreak the splines, it was about to fall off it was so loose, made steering kinda sloppy. So in the other 280z car i pulled the power steering rack pinon, or splined shaft out, because my old 36 spline steering shaft end had to be ground like a "V" for the old aluminum steering u joints. The new splined shaft was welded in place of the old splines, and has a nice tight fit with the new u joints, shouldnt have that issue now.
MTD off-road romper build. - Page 38 13650510
New splines vs the old "V" grinded steering splines.
MTD off-road romper build. - Page 38 13672610
MTD off-road romper build. - Page 38 13874610
New splines cut off and welded to the new steering shaft, now to make the new u joints to work with the slip steering column and finish a tie rod up.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 27th 2016, 11:05 pm
Looks pretty good. I don't think you'll have any more broken teeth now. Have to see if the ratio is much different now. Maybe it'll be a little quicker steering than with the worm gear.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 28th 2016, 1:13 am
Finished tie rod tonight, its 2 1/4 lock to lock. forgot what the old setup was, i think 3 turns lock to lock. Doesnt seem like its really all to different to me, maybe i gotta drive it.
And yea hopefully i dont have to do this again. Famous last words....
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 29th 2016, 8:59 am
this is great Tech Redline, nice work!
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 29th 2016, 10:21 am
New setup looks tough. Nice work
But won't you get more feedback through the wheel with a rack and pinion than you did with the worm gear?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 30th 2016, 1:38 pm
Thanks CC!
Probably, I'll have to see. I wouldn't think its more than I could handle though, besides its better than broken steering.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 30th 2016, 1:46 pm
This is true.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 31st 2016, 6:35 pm
Finished tie rod and mounts.
MTD off-road romper build. - Page 38 13867110
MTD off-road romper build. - Page 38 13883910
Modded the old skid plate supports, moved them around a little and bent up a new skid plate.
MTD off-road romper build. - Page 38 13900910
MTD off-road romper build. - Page 38 13866910
All painted up and re assembled.
MTD off-road romper build. - Page 38 13872511
MTD off-road romper build. - Page 38 13874710
Made light tabs.
MTD off-road romper build. - Page 38 13884510
Painted the front half of the frame, grill/shock hoops, fairlead, installed lights.
MTD off-road romper build. - Page 38 13872512
MTD off-road romper build. - Page 38 13884410
MTD off-road romper build. - Page 38 13898510
MTD off-road romper build. - Page 38 13866611
Carshowkid
Carshowkid
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 31st 2016, 6:56 pm
What type of coil overs are those and where did you get them?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJuly 31st 2016, 7:31 pm
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4077
rarbaugh07
rarbaugh07
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeAugust 10th 2016, 11:19 pm
Looks killer. Tim Cameron would drive it. Get brakes figured out?
Carshowkid
Carshowkid
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeAugust 10th 2016, 11:29 pm
What's your pulley swap? One to one?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeAugust 13th 2016, 1:15 am
its 4" to 4"
Haha, dude builds buggy in 3 weeks flat and now building another one in his spare time just to beat the hell out of it.
Yep, went riding with doug this past weekend and bought his old RV1 drum brake setup off of him.
MTD off-road romper build. - Page 38 Img_0110
Getting up to speed, Tractor was lookin good, but could be better. one of the front rims had a huge paint chip out of it. so i didnt prep it for sh*t. wire wheeled all 4 wheels down and used duplicolor wax remover, and man that stuff is awesome. pick up so much dirt i cant see. Painted them all black,, who woulds thunk. Bought a new camera too. Canon T5 eos rebel. my first dslr. Def digging these crazy good pictures.
MTD off-road romper build. - Page 38 Img_0011
MTD off-road romper build. - Page 38 Img_0010
Added a hood rack too. Thx for the idea mr.mod
MTD off-road romper build. - Page 38 Img_0012
Went to buddys house for a romp. some good pics. Got video of it too.
MTD off-road romper build. - Page 38 Img_0015
MTD off-road romper build. - Page 38 Img_0013
Figured out in the grass i can spin a half donut before it tries to catch and flip. Here i am pushing my luck in the dirt haha. No flippage but had to throw a kickstand out
MTD off-road romper build. - Page 38 Img_0016
MTD off-road romper build. - Page 38 Img_0014
Some screenshots from the video
https://www.youtube.com/watch?v=0JFKOv3QssY
MTD off-road romper build. - Page 38 Snapsh10
MTD off-road romper build. - Page 38 Snapsh11
Now.... Onto the odd part of all of this. Romp went great. Nothing broke. Ran great. Love the new steering. Loaded it up and headed home. Welp deer ran out behind a treeline, hardly saw it doing 60mph with trailer in tow. Hit me in the C pillar of my jeep as it was jumping and while in mid air the body grazed the tractor. Could say i got lucky, didnt hit it in the front. 90% sure i woulda totaled it if i did. Put a hand size dent in the side of the pillar, and pushed my hood in, broke the steering column at the weld, and smashed the dash up when it hit the steering wheel on the tractor.
MTD off-road romper build. - Page 38 13900711
MTD off-road romper build. - Page 38 13936610
MTD off-road romper build. - Page 38 13900710
I already pushed the hood out some, welded the column back together and fit it all back together. Tied the gas tank back up. still have a crack in the dash but i might just zip tie it, lol getting lazy here. Going to hook up dougs old brake system soon and then it should be about done.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeAugust 14th 2016, 9:19 pm
Needs new dash.
Now that I think about it, I might have one from when i had my pan frame MTD.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeAugust 17th 2016, 8:47 pm
Machine looking pretty high tech these days. Is your dash plastic?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeAugust 18th 2016, 10:47 am
Broken plastic dash - Some duct tape and wood screws lol Very Happy Very Happy
Axelsol89
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeOctober 15th 2017, 4:18 am
Hey redlinemotorsports been trying to message you but keeps freezing when I try I've got some questions about the spings your using I'm currently building a mini rockcrawler 190×70cm will be running 700mm wide solid front & rear diffs with 4 link suspension setup geared at 3.89 through a company in China with 23/7-10 ATV tyres I'll be running a big bored performance 125cc semi auto 3+R ATV motor with an atv reverse drive shaft to a Suzuki sierra/samurai transfer case geared high range 1.4 low range 2.5 roughly to run both diffs custom chassis/rollcage motor in front was gonna mount the fuel tank in the back and have a small fuel pump for pressure as far as front shocks I want alot of flex and was wondering how your springs are holding up? how much more flex could you get out of them? What setting do u have yours on? i was gonna run 400mm adjustable atv front shocks up my hole build will weigh as much as a 150cc buggy so any advice would be awesome thank you
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 7th 2024, 7:56 pm
So, not to be that guy bringing up a old, old thread..... but i like when one comes full circle.
Basically, since the last post i fixed it then went off to college. After i graduated, i immediately moved south in 2017. I dont believe i did much with it since then. So, this has been relatively untouched since the summer of 2017
Fast forward to now, I live down in NC with my own place. This past july i went up to my parents house with my truck and trailer to get this, the old jeep, and whatever few things i had left there. Quick 1400mi trip.
Just recently got it back running. Its been sitting outside and a little more weathered, but not to bad. Cleaned out the carb, and a battery. Im not sure what the future holds as far as going places with it, but we will see.
Planning on building a shop in spring so i can really get this back right, as well as my many other projects.
MTD off-road romper build. - Page 38 41128510
MTD off-road romper build. - Page 38 41101910
Video proof:
Last edited by redlinemotorsportts on January 7th 2024, 10:39 pm; edited 1 time in total
Brianator, Rustbucket Garage, PizzaKitty26 and ranch king pro 08 like this post
ranch king pro 08
ranch king pro 08
2023 Build-Off Top 3 Winner
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 7th 2024, 8:33 pm
Welcome back cheers
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 7th 2024, 8:34 pm
AH the tractor that inspired many builds in the past several years!  Reason I have 2 tractors with a monolink suspension.  Glad to see the ol' tractor coming back to life!  Welcome back  @redlinemotorsportts.  Great to see an OG member!
Oh when it is your own topic.  I see no issue reviving it that way.  cheers
MTD off-road romper build. - Page 38 Sig115PROJECTS:
MTD off-road romper build. - Page 38 Sig214MTD off-road romper build. - Page 38 Sig314
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 7th 2024, 9:24 pm
RAAAAAHHHHHH!!!!!!!! WELCOME BACK!!!!
MTD off-road romper build. - Page 38 B93bd110
Good Evening Ranch is March 22-24. Be there or be square. lol!
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 7th 2024, 9:41 pm
Eeeekkkk no way! Hes alive!
Espyville Mudders
White Trash Productions
Ohio Offroad Mowers
Top Tractor Challenge Host
#StopStretchingTractors2021
Builds: Sears Killer, Mud Dynamark, Drift Missile, 4x4 Dynamark + many more
https://www.youtube.com/user/redzz02
https://www.facebook.com/Redzz02
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 7th 2024, 10:52 pm
Well heck man it IS your thread! Lol. Love that lumpy idle, sounds mean
My All Terrain Tractors:
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 13th 2024, 6:19 pm
The legend returns!! My favorite build of all time by the way. Very Happy
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 38 Icon_minitimeJanuary 14th 2024, 12:11 pm
This could be a good year here. Good to see you still have the MTD!
Id love to see more of that Jeep too.
Page 38 of 38Go to page : Previous  1 ... 20 ... 36, 37, 38
» Craftsman 2 (YT16) romper "Basic B#$ch" build attempt
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
