| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
| Subject: Re: MTD off-road romper build. January 2nd 2016, 11:39 pm | |
| Ah nice, working out in the cold! Or did you work inside and then take pics in the cold? Anyway, I still can't see how the brakes got burned up in the short amount of time they were on there. Even cars get stuck calipers ect. go for miles and the pads aren't burned off right away. Really weird. Of course I don't know how close they were to start with. That rotor has a sort of rippled look to it in the pic though. Like it's realy been cooked or something. | |
| Subject: Re: MTD off-road romper build. January 3rd 2016, 12:04 am | |
| Nah man! Good ol camp, primitive tools i can find, crimping wire connectors with vice grips in the dark on dirt floors with a light snow coming through the door.
Pads were worn a little, ill take a pic sometime. Def enough to make them way out of adjustment. i think you can adjust the caliper and be able to use the hole pad, but if they keep burning out then the design isnt good. | |
| Subject: Re: MTD off-road romper build. January 3rd 2016, 1:40 pm | |
- Nah man! Good ol camp, primitive tools i can find, crimping wire connectors with vice grips in the dark on dirt floors with a light snow coming through the door.
Kerosene lantern hanging from the rafters. Sled dogs sleeping in the corner. | |
rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4077 Posts : 117 Location : Logan, iowa
| Subject: Re: MTD off-road romper build. January 20th 2016, 4:51 pm | |
| Steering box probably just bound up, but it would be worth looking into. You been using the exhaust cut out or mostly the muffler? Still sounds good even with the carb/lack of power issue. | |
| Subject: Re: MTD off-road romper build. January 20th 2016, 5:21 pm | |
| - mr.modified wrote:
- Rare steering box now damaged and waiting to explode at haspin.
If it is damaged I'll just swap. I think if im lucky i only chipped the pinion tooth, and thats removable. - rarbaugh07 wrote:
- Steering box probably just bound up, but it would be worth looking into. You been using the exhaust cut out or mostly the muffler? Still sounds good even with the carb/lack of power issue.
Yea, im pretty sure its broke just by the feel of it. The pitman arm bent down a little too, so need to stuffin it up a little. I think the beginning was open all the way to where i slide down the hill then the mufflers were on for the rest of the video. | |
Rockinator Member
Age : 23 Join date : 2016-01-16 Points : 3409 Posts : 164 Location : Canada
| Subject: Re: MTD off-road romper build. January 20th 2016, 6:24 pm | |
| Looks like a awesome time. Your Lucky that the ice is hard enough for you to drive on. Never freezes enough here for some reason. That sucks about the steering. If you only chipped a tooth your lucky. With my luck it would've ate the steering box and anything else in the way. | |
| Subject: Re: MTD off-road romper build. January 21st 2016, 12:16 am | |
| - Rockinator wrote:
- Looks like a awesome time. Your Lucky that the ice is hard enough for you to drive on. Never freezes enough here for some reason. That sucks about the steering. If you only chipped a tooth your lucky. With my luck it would've ate the steering box and anything else in the way.
I hope i chipped the pinion gear, then its a easy fix, ill have to see. Just a little more work to swwap a new box in guess. Aluminum u joint is getting wobbly pretty bad, going to swap in a steel one so it splines onto the steering colum better. | |
STUNTMAN JON Member
Age : 39 Join date : 2016-01-22 Points : 3334 Posts : 100 Location : Belfast Northern Ireland
| Subject: Re: MTD off-road romper build. January 25th 2016, 1:05 pm | |
| Thats some machine, the drivers pretty good too ! looks like I've a lot of good stuff to look through on here, thanks for sharing, Jon | |
| Subject: Re: MTD off-road romper build. January 25th 2016, 3:05 pm | |
| - STUNTMAN JON wrote:
- Thats some machine, the drivers pretty good too ! looks like I've a lot of good stuff to look through on here, thanks for sharing, Jon
Thanks! | |
mowerheadder New Member
Join date : 2016-04-28 Points : 3159 Posts : 20 Location : New Jersey
1997 Murray Veteran Member
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
| Subject: Re: MTD off-road romper build. July 13th 2016, 1:00 am | |
| Yea it looks more up to date. Im really trying to make this look more clean and better. Anywho, time to cut all the junk off and re start. I torched the spring buckets/shock towers off and unbolted the grill. i cut off the other winch mounting spot, it was a little un even so i got it really squared away and boxed the ends for strength. With a bunch of smoothing out of the way now, i started on the lower shock tabs. Template to actual tab. Went and got some push mower handles for bends on the shock hoop. i know what your thinking, flimsy and what not, but i honestly think its pretty good. I cant hardly get them to flex around. I could add a bar up top to tie the bars together, but thats up for debate. Cut out and welded on some top tabs too. I also tried something new, with joining the tubes together. People generally use something called "slugs" to fit inside the pipe, gap the pipe 1/8" or so and then you get a really good weld penetration in the gap. i did the same thing, but i slit some of the same tube and put it inside the pipe. Some poser shots. Also been busy on revamping the welding cart. The caster suck so bad in the stone driveway, so i put some old wheels i had laying around on, and built a front steer axle for it. | |
Doug Site Owner
| Subject: Re: MTD off-road romper build. July 13th 2016, 6:45 pm | |
| Should bolt those lights I sold you to the top mount on those. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: MTD off-road romper build. July 13th 2016, 9:13 pm | |
| I think it would look really clean if you put the lights behind the mesh grille to kind of hide/protect them | |
