 MTD off-road romper build.
ranch king pro 08
Axelsol89
mowerheadder
STUNTMAN JON
Rockinator
WilliesBuilds
98svtcobra
MurrayMayhem
jack9102
802 Customs
untrusty huskee
Carshowkid
rarbaugh07
ZSmachines
Deluxe66
Jerbear0612
Moose
Angchor
B440
jamcco
Craftsman1998
breadtrk
camomanusa
mrkadage
MoWheeler
mzeng100
T-Dub13
GenevaCustoms
muddstir
TroyBilt Pony
cumminsbayou
crazykid1994
xxXMowerdudeXxx
genegillis5
Jamus
MowBandit
1993-Sierra-Z71
motorizedeverything
flamudmower
Murray modder
Chopperhed
Ddwannabe
mudmonkey06
70 posters
Go to page : Previous  1 ... 11 ... 19, 20, 21 ... 29 ... 38  Next
TroyBilt Pony
MTD off-road romper build. - Page 20 Empty
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 5:40 pm
Looks good red! Is it gonna be cable? Chain? Strap? rope?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 6:00 pm
Looks great, You never seem to stop amaze us with your ideas  Very Happy  - Will it have a holding brake drum?  tongue
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 6:08 pm
Cable, little hook, any maybe some D rings up front?
I think ill get some 3/4" washers and have the axle itself be the drum. The cable might get a little twisty being a small drum but its A LOT stronger then what i can think up right now. I will maybe bump it up to a 1" drum if i can find a piece of pipe that has a 3/4" inner bore.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 6:12 pm
Thunderdivine"]Looks great, You never seem to stop amaze us with your ideas Very Happy - Will it have a holding brake drum?  tongue
Yeah but a holding brakedrum, like a brake.
And you could use some tiny rims stacked.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 6:15 pm
Oh i see. No plans for a drum brake yet. the jacobsen (where i got my fnr foote) had the brakes on the pulley (yikes!) so ill look at that design.
MoWheeler
MoWheeler
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 6:59 pm
1997 Murray wrote:
i guess not.......... got to get me one of those 820's..
I think that is a pressure lube oppy. I sold one to a racer for over 400$..
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 7:00 pm
Ill check it it next time. I think they made the pressure lube the last few years and that was like 2002 or something. And that doesnt look like a 2000's tractor to me lol
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 10:06 pm
Really like the idea of the pto winch, typical redline, out of the box thinking with good planning and design. As far as your "drum" 1 inch tubing with .125 wall would have a 3/4 ID
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 26th 2014, 10:08 pm
Thanks i appreciate it. Yea id like a little bit bigger drum, so ill search my parts pile for something. if not no big deal. Some guys talked about brakes for it so ill have to integrate that somehow.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 3:33 pm
Will #40 chain fit on this?
MTD off-road romper build. - Page 20 15576710
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 4:38 pm
Got a video of the progress too.
T-Dub13
T-Dub13
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 8:27 pm
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 8:42 pm
Thanks a bunch t-dub. I read about it and they said .500" length fot teeth but didnt specify the measuring points.
T-Dub13
T-Dub13
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 8:48 pm
No sweat Red,
Actially, the correct measiring points are the centers of the rollers on the chain (shown) and the centers of the roller cavity (for lack of better terms) on the sprocket. The sprocket is incorrectly labeled for points of measure, but the peaks of the teeth are close enough!  cheers
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 9:12 pm
as far as a brake for the winch, why not use a small mechanical caliper on the sprocket its self? I remember seeing a rear engine tractor at the junkyard that had that setup
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 27th 2014, 11:13 pm
I thought of that, but the 8T and 40 T will be really close together for mounting so, in chat, Thunderdivine suggested some transaxle brakes. maybes good sence, maybe something with a band brake, or maybe a rotor if i can find a caliper that fits. lots of things that could work, so ill keep my eyes open.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 28th 2014, 2:47 pm
Well someone on youtube helped me out on a broken gear in my foote gearbox. I dont need forward gears, just need gears incase one decides to blow again. They told me that MTD FNR axle bevel gears are the same and he used em in his. Well off to the internet! Sears helped my out providing this diagram of the gears. IF everything fits (witch it looks like it does) id have to switch both gears and part #17 and it will all work. Good to know!
MTD off-road romper build. - Page 20 Screen18
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 29th 2014, 7:37 pm
Nifty looking winch. I haven't checked up on this in a while. What's your idea for engagement of the belt? Hand or foot operated?
PostSubject: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 29th 2014, 8:01 pm
this is the thread i wanted to respond to, don't you have the f-n-r tranny that was in this originaly? couldn't you rob parts off of that instead of buying them?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 29th 2014, 8:55 pm
Yep belt engagement with a lever like a mower deck lever. something you can push or pull and lock in engagement.
Rob parts? what do you mean, my stripped gears? someone on youtube said i should be able to swap gears out (shown above) but he hast tested the gearbox out with new gears. If you mean by the axle itself, its a little to big for my tastes i guess, i mean originally i was just gunna have the orange gearbox and a spool right off the output shaft but ratios were way to high.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 29th 2014, 9:21 pm
Band brake would work real good. Lever actuated with a good strong spring should get you great results.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 29th 2014, 9:54 pm
Yea just gotta figure out a caliper. Speaking of brakes ill need to upgrade my transaxle brake to what the mowrons have because mine barely slows it down now
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 30th 2014, 5:40 am
I still don't have brakes.  I have been getting used to it. LOL
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 30th 2014, 9:08 am
I rarely use em. But when winching I need them to lock the rear tires if in pulling someone out. Or set the bumper on a tree as a stopper
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 30th 2014, 9:06 pm
Worked on the winch and tack welded everything. Still need holes drilled for the tranny and jackshaft. Lights arnt mounted, they acually wont work how i have them in the pics
MTD off-road romper build. - Page 20 10132010
MTD off-road romper build. - Page 20 17956110
MTD off-road romper build. - Page 20 16186610
MTD off-road romper build. - Page 20 10034011
MTD off-road romper build. - Page 20 15442910
MTD off-road romper build. - Page 20 17946710
MTD off-road romper build. - Page 20 15605011
Last edited by redlinemotorsportts on January 31st 2014, 10:00 am; edited 1 time in total
PostSubject: MTD off-road romper build.   MTD off-road romper build. - Page 20 Icon_minitimeJanuary 31st 2014, 9:47 am
nice!
Page 20 of 38Go to page : Previous  1 ... 11 ... 19, 20, 21 ... 29 ... 38  Next
» Craftsman 2 (YT16) romper "Basic B#$ch" build attempt
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
