| MTD off-road romper build. | |
+66MightyRaze ranch king pro 08 Axelsol89 CraftsmanQuad19 mowerheadder STUNTMAN JON Rockinator prancstaman MatthewD WilliesBuilds 98svtcobra MurrayMayhem jack9102 802 Customs untrusty huskee redlinemotorsportts Carshowkid rarbaugh07 mr.modified ZSmachines Deluxe66 Jerbear0612 Moose kawasaki220 Angchor B440 jamcco Craftsman1998 breadtrk camomanusa mrkadage MoWheeler Lawren Wimberly mzeng100 TheBeal T-Dub13 richie thomas GenevaCustoms muddstir 1997 Murray TroyBilt Pony Stretch44875 willis923 cumminsbayou crazykid1994 Creepycrawler k2500life xxXMowerdudeXxx genegillis5 TheRainbowBoxer Jamus LAWN MOWER MUDDER MowBandit 1993-Sierra-Z71 craftsmancole Doc Sprocket motorizedeverything flamudmower Murray modder Chopperhed Thunderdivine Ddwannabe mudmonkey06 Ariens YT11 Doug truckin42 70 posters |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6400 Posts : 1434 Location : east dublin georgia
| Subject: Re: MTD off-road romper build. December 8th 2013, 8:27 pm | |
| - richie thomas wrote:
- i got a kawa , your lucky getting all these motors man, i need another v-twin
Dont we all. LOL | |
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4415 Posts : 315 Location : Florida
| Subject: Re: MTD off-road romper build. December 8th 2013, 8:28 pm | |
| - TroyBilt Pony wrote:
- this ranch king tucked 25s with fender trimming and stock axle location.. only would have took like 2 inched to clear fenders but we just chopped the fenders
DONT YOU JUST LOVE THE FAT MAN CHAIR HAHA It had more clearance, the tranaxle was snapped in 2.. That's not fender trimming, lol you have no fender left hahahah but it looks sweet | |
| Subject: Re: MTD off-road romper build. December 8th 2013, 8:30 pm | |
- The newer mtd axles with the center pumpkin are tougher. I don't know how the pony's didnt go. That tractor took so much ***** and smiled back.. lol
You think they are? There on the newer ones so I thought they might be, that's what I want for the front end on my 4x4 | |
Join date : 2013-06-01 Points : 4810 Posts : 578 Location : West Virginia
| Subject: Re: MTD off-road romper build. December 8th 2013, 8:39 pm | |
You think they are? There on the newer ones so I thought they might be, that's what I want for the front end on my 4x4 They definately are, my pony had 1 rear end, running stock grease, ranch king had 3 w/ the short/ long axle setup.. And the pony had more abuse. I used to break by slamming it into reverse lol | |
T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4572 Posts : 540 Location : Central MA
| Subject: Re: MTD off-road romper build. December 11th 2013, 1:46 pm | |
| Dual Carb-a-Tooties! That's epic man. That warrants some sweet looking paper filters or maybe a couple giant velocity stacks. | |
1997 Murray Veteran Member
| Subject: MTD off-road romper build. December 11th 2013, 1:52 pm | |
| I have a tecumsea 17 hp single with the sane carb you got there. but only one, it is a very strong engine. I bet that thing has a ton of power! where do you get all of these things? | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 2:47 pm | |
| I get them at my junkyard. I usually snatch them up the say I see them or the day after. | |
| Subject: MTD off-road romper build. December 11th 2013, 2:53 pm | |
- redlinemotorsportts wrote:
- That's what happens when you weld a rim to a rim and run a FNR..... Mtd junk
No, thats what happens when your frame is cracked and all the pressure is on the axle, the tractor has been through 16 roll overs, pulled many mowers out of the woods (remember, its all up hill on the way out where we romp..) People crack those axles in half so much. usually with stock turf tires, unlocked.
Heres just one picture off hand of a buddies axle on fb.
I've broke my dad's MTD transaxle four times, turfs, unlocked, good grease, mowing the lawn. I wheighed 150 lbs. I don't think that had anything to do with it. | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 2:56 pm | |
| Yeah, I'm not a fan of these things at all. No matter how there made. Seen them all die | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 3:21 pm | |
| I thought a truss would be cool, just welded to the case via tig or mig. Sounds like a good idea tho. I have a 820 for my offroader, so I can get new meaty tires, and not have to worry about breakage.
Last edited by redlinemotorsportts on December 11th 2013, 3:33 pm; edited 1 time in total | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 3:23 pm | |
- I thought a truss would be cool, just welded to the case via tig it mig. Sounds like a good idea tho. I have a 820 for my offeoader, so I can get new meaty tires, and not have to worry about breakage.
If you romp hard.. you can break anything lol. If a guy can break a rockwell.. you can break a 820 lol | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 4:11 pm | |
Its not like is have gobs or torque anyways lol. i have alot less chance of breaking the case anyways | |
Thunderdivine Veteran Member
| Subject: Re: MTD off-road romper build. December 11th 2013, 6:55 pm | |
| - Thunderdivine wrote:
- Are they that strong? the 820's?
I'm gonna say easily top 3 toughest common transaxles. | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 7:15 pm | |
| Yea, there one of the strongest vertical input teansaxles I know of. The rear beef is the horizontal inputs | |
Age : 37 Join date : 2013-07-02 Points : 5019 Posts : 731 Location : Logan Ohio
| Subject: Re: MTD off-road romper build. December 11th 2013, 8:15 pm | |
| 820 are top notch for bottom shaft, but like Redline said, the real beef trannys are the horizontal inputs | |
| Subject: Re: MTD off-road romper build. December 11th 2013, 8:30 pm | |
| - Creepycrawler wrote:
- 820 are top notch for bottom shaft, but like Redline said, the real beef trannys are the horizontal inputs
and i got one | |
