 MTD off-road romper build.
ranch king pro 08
Axelsol89
mowerheadder
STUNTMAN JON
Rockinator
WilliesBuilds
98svtcobra
MurrayMayhem
jack9102
802 Customs
untrusty huskee
Carshowkid
rarbaugh07
ZSmachines
Deluxe66
Jerbear0612
Moose
Angchor
B440
jamcco
Craftsman1998
breadtrk
camomanusa
mrkadage
MoWheeler
mzeng100
T-Dub13
GenevaCustoms
muddstir
TroyBilt Pony
cumminsbayou
crazykid1994
xxXMowerdudeXxx
genegillis5
Jamus
MowBandit
1993-Sierra-Z71
motorizedeverything
flamudmower
Murray modder
Chopperhed
Ddwannabe
mudmonkey06
70 posters
Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 23 ... 38  Next
motorizedeverything
MTD off-road romper build. - Page 9 Empty
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 12:40 pm
are you going to add cross bracing
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 4:39 pm
Lmm/edi-thanks guys.
Motorized-no I'm not not a lot of space to do it. The one side feels really strong
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 7:28 pm
Looks great red! I noticed your rear clutch pulley is bent 3-5 degrees compared to the front one, is there a meaning for this?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 8:09 pm
its a double pulley clutch and both pullys are level. It's probably just the camera lol
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 8:11 pm
Yea probably
motorizedeverything
motorizedeverything
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 8:36 pm
Yea probably
but if you look at the strait plate then it looks bent just barley though
MTD off-road romper build. - Page 9 93651410
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 2nd 2013, 8:40 pm
If you want to go back in the thread and check out when I made the clutch go ahead. The clutch ass. is 1/2" higher than the rear pulley but I don't thing that will affect anything.
Last edited by redlinemotorsportts on December 4th 2013, 8:29 am; edited 1 time in total
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 3rd 2013, 8:09 am
I really like all the work you've done with this, it will be a solid tractor when your done, did you swap back to a unlocked rear axle? I know you said you didn't like yours locked
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 3rd 2013, 10:25 am
I haven't got around to going to the junkyard getting one but the axles can move around in the case, really worn down. That's another big reason why I want another transaxle
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 6th 2013, 11:01 pm
Got a few things done today.
More hp boosters:
MTD off-road romper build. - Page 9 10014010
MTD off-road romper build. - Page 9 98870410
Well I repeated the process on the other side, bracing. this side had a big slot cut out for the stock pully. I plated it up.
MTD off-road romper build. - Page 9 99658710
MTD off-road romper build. - Page 9 99430510
Paint....zing!
MTD off-road romper build. - Page 9 93653110
Steering rod and a poorly done exhaust need love. didn't like the gray on the exhust but I need high temp paint.
MTD off-road romper build. - Page 9 10169510
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 8th 2013, 8:15 pm
I pulled the mower out to see if the frame flexed any more after the bracing I did. ill try some more positions too but it looks great.
MTD off-road romper build. - Page 9 11503211
MTD off-road romper build. - Page 9 21663_11
Front tire was bearly touching the ground. this is the improvement it made: (before after)
MTD off-road romper build. - Page 9 10103610
MTD off-road romper build. - Page 9 11501610
Liking it so far.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 9th 2013, 11:16 pm
Changed oil in the tractor but not worth its own update, so ill show you my garage for a change.
MTD off-road romper build. - Page 9 52631510
MTD off-road romper build. - Page 9 10114310
Aint the best but definatly happy happy happy that I have it.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 10th 2013, 9:56 pm
I put my second clutch spring on but the hole that I used to use (was a previous hole in the chassis) was blocked  by the new frame braces. I took a thick washer and just welded it on.
MTD off-road romper build. - Page 9 11464910
MTD off-road romper build. - Page 9 11487910
Its not complete without a proper test drive.
MTD off-road romper build. - Page 9 15648_11
MTD off-road romper build. - Page 9 10019510
motorizedeverything
motorizedeverything
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 11th 2013, 4:37 pm
i wish my shop was that big
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 11th 2013, 7:46 pm
I'm fortunate to have what I got
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 12:22 am
How about a big change? Leaf srings, from a 440 cheetah (lol)
MTD off-road romper build. - Page 9 10116110
Got these off a old chase tractor. just for a later project.
MTD off-road romper build. - Page 9 10046711
MTD off-road romper build. - Page 9 57964310
MTD off-road romper build. - Page 9 11761310
MTD off-road romper build. - Page 9 11753010
Rough moc up. I need a nice drill bit for my 1/8" stainless "tabs" or drop down bracktes too.
MTD off-road romper build. - Page 9 10169911
MTD off-road romper build. - Page 9 10885_10
MTD off-road romper build. - Page 9 99549010
With the hood on:
MTD off-road romper build. - Page 9 58179510
MTD off-road romper build. - Page 9 97036210
Beginning of underbracing
MTD off-road romper build. - Page 9 99578610
List of things to do: new bolts/nuts/washers, paint, supports, steering, fab work. Looks like I need to cut a bit off the bottim of the hood too, so that needs pain to (I never painted the boxed wrenches on the bottom)
motorizedeverything
motorizedeverything
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 8:17 am
this is very interesting
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 7:38 pm
In-giggady
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 8:29 pm
It's gonna be awesome though
http://www.lastdropgarage.com
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 9:24 pm
More progress. Better pics too. I still need a drill bit for mounting plates, thinking 1/4" steel, and need to work on the leaf spring packs, and finish welding.
Heres with the hood on, I didn't have to chop it up, im very happy I didn't.
MTD off-road romper build. - Page 9 10949510
MTD off-road romper build. - Page 9 10052310
build pics:
MTD off-road romper build. - Page 9 20490_10
MTD off-road romper build. - Page 9 11509910
MTD off-road romper build. - Page 9 11757410
MTD off-road romper build. - Page 9 11854010
MTD off-road romper build. - Page 9 11861410
MTD off-road romper build. - Page 9 11861510
MTD off-road romper build. - Page 9 11747710
MTD off-road romper build. - Page 9 99942110
MTD off-road romper build. - Page 9 10980710
MTD off-road romper build. - Page 9 10984710
MTD off-road romper build. - Page 9 11577010
MTD off-road romper build. - Page 9 11850610
MTD off-road romper build. - Page 9 55797710
Look closely, there are some things that are temporary... LOL
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 9:27 pm
I LOVE the leaves! But- spin them around- eyes forward, slippers back.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 9:30 pm
Ill check clearance, how much they slide, I don't want them to hit my foot-clutch-bar-thingy....LOL
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 9:36 pm
yep leaves ride much nicer with the fixed end at the front of the vehicle, but it will be fine like you have it also
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 15th 2013, 9:40 pm
yep, I just have to see how much they slide, I wish they had shackles but then again its off a snowmobile haha.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 16th 2013, 5:59 am
When you build the slipper retainers, leave maybe 1/16"-1/8" of room top to bottom, and side to side for them to move. Much more than that, and they'll be pretty sloppy and noisy. Much less, and they will bind up too much. Replace the bushings at the eye end, too. You may want to consider removing a leaf to soften them up a bit for offroad use. When you put the full weight of the frontend on them, do they deflect at all? I'm guessing they're a bit too stiff as they are. Either way, I love the leaf springs. Good on ya for using them!
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 9 Icon_minitimeAugust 16th 2013, 4:28 pm
Ill keep that in mind when I build the springs. They seem kinda soft, at leafy wen I put my full weight on one (witch ain't much LOL) it seems to flex about a inch down. When I mocked it up yesturday they sagged slightly. I don't have a problem with taking one out if it seems to hard. Can't wait to ride this.
Page 9 of 38Go to page : Previous  1 ... 6 ... 8, 9, 10 ... 23 ... 38  Next
» Craftsman 2 (YT16) romper "Basic B#$ch" build attempt
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
