 MTD off-road romper build.
ranch king pro 08
Axelsol89
mowerheadder
STUNTMAN JON
Rockinator
WilliesBuilds
98svtcobra
MurrayMayhem
jack9102
802 Customs
untrusty huskee
Carshowkid
rarbaugh07
ZSmachines
Deluxe66
Jerbear0612
Moose
Angchor
B440
jamcco
Craftsman1998
breadtrk
camomanusa
mrkadage
MoWheeler
mzeng100
T-Dub13
GenevaCustoms
muddstir
TroyBilt Pony
cumminsbayou
crazykid1994
xxXMowerdudeXxx
genegillis5
Jamus
MowBandit
1993-Sierra-Z71
motorizedeverything
flamudmower
Murray modder
Chopperhed
Ddwannabe
mudmonkey06
70 posters
Go to page : Previous  1 ... 13 ... 22, 23, 24 ... 30 ... 38  Next
MTD off-road romper build. - Page 23 Empty
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 3:40 am
Nope... it looks like the tractor Just had it's temperature taken 0.0
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 9:26 am
Red, I think your front-end is still a little messed up. I think it's still a little bent. Also it looks like you have some extra caster that could wear down your front tires.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 10:21 am
Nothing is bent in the front end other than the grout spindle from the backwards roll over. I just bent it back down but it looks like I didn't bend it down enough. But it hasn't been bending back up so I'm not worried about it.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 10:27 am
Spaghetti spindles.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 2:37 pm
Doug Fackler wrote:
Spaghetti spindles.
Typical MTD right??
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 2:58 pm
Doug Fackler wrote:
Spaghetti spindles.
Typical MTD right??
Yea typical. If they went any smaller, it would probably be pencil spindles.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 7:53 pm
swap in a axle out of a larger mtd like the pony. It had 5/8 or 3/4.. i forget. but they were pretty sturdy.
B440
B440
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 8:05 pm
I gotta say that is a very creative idea with the winch. I like it a lot.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 16th 2014, 10:11 pm
I could swap it out with a GT murray in the junkyard right now.... 7/8 Spindles. BUT, im cheap.
Thanks! I appreciate it.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 22nd 2014, 11:22 am
Well anyways little update. Been seeing this tractor and knew it had a 820 so i nabbed it up last weekend. Paid like $15 for the axle and got whacked $20 because of the tires. if it was just rims i probably wouldn't be whacked with a extra $20 but i cant get them off in the yard. This will be a spare axle.
Murray GT
MTD off-road romper build. - Page 23 19476210
In the garage inspecting it
MTD off-road romper build. - Page 23 19593010
MTD off-road romper build. - Page 23 19597810
Taking tires off the old fashion way lol
MTD off-road romper build. - Page 23 19723911
Tried taking of the pulley with a slide hammer but had a brain fart. forgot the clip on the input shaft isnt that strong. Popped the shaft out on the vice anyways.
MTD off-road romper build. - Page 23 19117910
Removed rims. One was siezed but took a few min to drive the axle out with a punch and sledge.
MTD off-road romper build. - Page 23 18978811
Opened it up and looks fairly clean.
MTD off-road romper build. - Page 23 19082310
I knew it had a shifting problem and found out the shifting fork's spot weld broke.
MTD off-road romper build. - Page 23 14976811
The indent and shiny dot above it look like they should be on top of each other. No matter, my other 820 is still apart so ill just run a small bead.
MTD off-road romper build. - Page 23 1843_410
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 12:12 pm
Finally got around to switching up the clutch.... It wasnt on the slack side so i just switched it around to the slack side and did some changes
Found out the original clutch was bent slightly...
MTD off-road romper build. - Page 23 19040110
Plated it and added that spacer so the clutch hung lower and more in line with the belt.
MTD off-road romper build. - Page 23 19666910
Drilled a hole in the sheet metal frame and welded this spacer so the hole doesnt egg out from the pivot bolt and act as a spacer as well.
MTD off-road romper build. - Page 23 10155110
Took the linkage off that connects the foot petal to the clutch and found out how worn it is! i got my spare drag link and cut the end off, and now its a rod end, much better and still adjustable.
MTD off-road romper build. - Page 23 10013810
Modified original linkage and welded the rod end on.
MTD off-road romper build. - Page 23 18976510
Everything is close but doesnt touch, might touch a little when the belt whips around.
MTD off-road romper build. - Page 23 12396910
Modified my original spring, if you remember i have a bolt that that tightens it, well i couldnt find all thread so i welded a long bolt to the original bolt (long and ghetto) and that runs back to me original brace with a washer and a nut that draws the spring tight.
MTD off-road romper build. - Page 23 15349910
Test runs! Works awesome, little foot petal chatter, but it rips. The single spring is a lot easier and more controllable to push.
MTD off-road romper build. - Page 23 Wheeli11
5th gear drops. Spins.... Woo hoo!
MTD off-road romper build. - Page 23 10169210
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 12:17 pm
lol nice, did you notice alot of difference from having the clutch on the torque side opposed to the slack side?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 12:51 pm
Totally, it would slip on start off amything above 2nd. Grabs in any gear great now
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 3:07 pm
But can it spin on pavement? That would be accomplishment x1000 or something lol
But still, Cool!
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 3:36 pm
nope lol, hooks right up on that locked tranny. Maybe one last snow run if the snow does come
jamcco
jamcco
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 5:10 pm
same exact thing happened to me lol
B440
B440
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 8:58 pm
haha I like that wheely-action shot
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 29th 2014, 11:06 pm
Yep, gunna make up a test video in the next week or two
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 30th 2014, 3:23 pm
Heres some new tires... 19X7-8 little wider then id like but much better then what i got now.
MTD off-road romper build. - Page 23 96929210
MTD off-road romper build. - Page 23 10157311
MTD off-road romper build. - Page 23 10171612
MTD off-road romper build. - Page 23 10157312
Now i gotta make some clearance to make them fit... lol. I was thinkin bout widening the axle (i have the same spare MTD axle beam) because welding rims to rims making them super wide is asking for bent spindles. Feedback on the axle widening thing guys?
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 30th 2014, 5:35 pm
Sounds like something i would do, its probably the best way to do it honestly. rims to rims works but isnt right.
In deep water, you will like the wider tires. they keep your feet drier lol
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 30th 2014, 5:39 pm
I dont think they will float but will definitely add some bouncy  Rolling Eyes  And i totally agree with you on the top part. I think imma chop it.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 30th 2014, 5:59 pm
Hey red can you get the model and manufacturer's brand for those tires?  Those look like something that would be beastly on the back of my rally.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 31st 2014, 6:55 pm
I didnt forget about you.
MTD off-road romper build. - Page 23 10013910
Tires are good, has them at 20 psi yesterday and still the same today
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 31st 2014, 8:34 pm
better drop that psi to like 6psi atleast.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 31st 2014, 8:40 pm
Well its not like their on the tractor Razz
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 23 Icon_minitimeMarch 31st 2014, 9:07 pm
I think they need 40 psi.
Page 23 of 38Go to page : Previous  1 ... 13 ... 22, 23, 24 ... 30 ... 38  Next
» Craftsman 2 (YT16) romper "Basic B#$ch" build attempt
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
