 MTD off-road romper build.
ranch king pro 08
Axelsol89
mowerheadder
STUNTMAN JON
Rockinator
WilliesBuilds
98svtcobra
MurrayMayhem
jack9102
802 Customs
untrusty huskee
Carshowkid
rarbaugh07
ZSmachines
Deluxe66
Jerbear0612
Moose
Angchor
B440
jamcco
Craftsman1998
breadtrk
camomanusa
mrkadage
MoWheeler
mzeng100
T-Dub13
GenevaCustoms
muddstir
TroyBilt Pony
cumminsbayou
crazykid1994
xxXMowerdudeXxx
genegillis5
Jamus
MowBandit
1993-Sierra-Z71
motorizedeverything
flamudmower
Murray modder
Chopperhed
Ddwannabe
mudmonkey06
70 posters
Go to page : Previous  1 ... 13 ... 23, 24, 25 ... 31 ... 38  Next
MTD off-road romper build. - Page 24 Empty
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeMarch 31st 2014, 9:07 pm
I think they need 40 psi.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeMarch 31st 2014, 9:49 pm
Doug fackler everybody.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeMarch 31st 2014, 10:25 pm
thats my kinda' song
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 1st 2014, 9:21 pm
How deep is the tread on those tires? I've been looking around a little for some but would like more info on them.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 1st 2014, 9:23 pm
Mine are maybe 3/16"-1/4" but the new ones look like they have double. Krawler86 on here has some for sale i think?? Or he used some on his build.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 1st 2014, 9:37 pm
Smart minds think alike??  Right before i refreshed the page and read this I was like "Krawler86 used some on his build!".  Coincidence, no?
The more I see them the more I wonder...
"do I want directional tires in the first place"
"should I use ags or holeshots (which I could probably get cheaper)"
"or should I just get them and get it over with?"
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 1st 2014, 9:50 pm
Maybe start a thread on tires.
What size you want
How much you'll spend
Driving conditions and habits
What your looking for in a tire
Lots of tire freaks on here that can help you out.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 1st 2014, 9:51 pm
ummm.. i made a woopsy lmao
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 4th 2014, 11:55 pm
So i got them 19's, now its time to make them fit.
Cut some spare stock front rims up and centered and welded these to the ATV rims i got.
MTD off-road romper build. - Page 24 10169211
Removed axle.
MTD off-road romper build. - Page 24 10171112
Cut 2" from original axles center section. Then cut a 6" center from a parts axle. Made it 4" wider
MTD off-road romper build. - Page 24 10247111
Welded and grinded seams down.
MTD off-road romper build. - Page 24 18885911
MTD off-road romper build. - Page 24 10154911
Cut out 4 -2" square plates and plated the seams.
MTD off-road romper build. - Page 24 17957610
MTD off-road romper build. - Page 24 17791710
Made the tie rod longer.
MTD off-road romper build. - Page 24 16010510
Letting it stretch. Checking clearances.
MTD off-road romper build. - Page 24 14558810
MTD off-road romper build. - Page 24 10013510
MTD off-road romper build. - Page 24 10102211
MTD off-road romper build. - Page 24 10013511
camomanusa
camomanusa
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 5th 2014, 12:50 am
damn... it looks great! nice welding job
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 5th 2014, 12:52 am
Thanks lol, now i just need to put in the 820 and tires!
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 5th 2014, 11:07 am
looks like its got a bit of a backwards lean
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 5th 2014, 2:36 pm
That problem should be fixed before summer.
=`w`=
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 5th 2014, 3:02 pm
=`w`=
when you put the 820 in it, you should make a spacer to have the tires sitting even
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 5th 2014, 5:54 pm
=`w`=
The 12" rims are a 1" wider and offset vs mine that are on it now. It will be close enough. It is what it is
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 6th 2014, 5:05 pm
=`w`=
Didja figure out what size and brand/model tires you are going to put on it yet?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 6th 2014, 5:18 pm
Nope, not really the whole frame.  Just the hood is at a backwards lean, if you look at the foot boards they are level.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 6th 2014, 5:27 pm
=`w`=
Yea, but i wont say till i mount them up, i procrastinate a lot.
=`w`=
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 6th 2014, 8:55 pm
nah, i bet if you put a ball on the floorboard it would roll back. looks like a pretty decent angle to me.
red, you could always squish the leafs down a bit too, if need be, or re mount them
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 6th 2014, 8:58 pm
Floorboards are about level, maybe front about a inch or so higher then the rear frame.
If i do that will then i lose leaf travel , and i will take all i can get especially with the jumping.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 10th 2014, 6:57 pm
Make the hood level and let the air to 1psi in the front tires. Or step the front axle a little.
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 10th 2014, 7:14 pm
Nah. I like the hood and don't want to cut it again. And 6ish paid fine.
=`w`=
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 22nd 2014, 10:27 am
why did you have to mount the twin that way? coulden't you mount it nomally?
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeApril 22nd 2014, 11:03 am
Heads of the engine are wider then my hood, so if have to chop the bajesus out if it for the hood to fit over the engine. Plus it bolts up to the singly cyl's stock mounting holes this way.
Angchor
Angchor
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeMay 5th 2014, 5:05 pm
A picture being worth a thousand descriptions... Here is a visual aid.
MTD off-road romper build. - Page 24 Aid10
PostSubject: Re: MTD off-road romper build.   MTD off-road romper build. - Page 24 Icon_minitimeMay 29th 2014, 12:56 pm
thats cool when you going to put the new trans and bigger tires on it
Page 24 of 38Go to page : Previous  1 ... 13 ... 23, 24, 25 ... 31 ... 38  Next
» Craftsman 2 (YT16) romper "Basic B#$ch" build attempt
» Tractorhead's Roper Romper [2016 Build-Off Finalist]
» SS-16 OFF-ROAD BUILD
» MTD Off Road Build
