| idea to use a hydro tranny to chain drive to make an automatic | |
+4dylansrockinrigs Chopperhed Doug xxXMowerdudeXxx 8 posters |
xxXMowerdudeXxx Established Member
| Subject: idea to use a hydro tranny to chain drive to make an automatic March 8th 2013, 10:46 pm | |
| ok, ive got this idea. what if you get a mower with a hyro in it, you put a massive lift like ffs, but you leave the hydro in place, put a sprocket on the right axle and run a chain down to the tires with a live axle. and gear the chain so it goes decently fast. then you will have an automatic mower, just push the old petals to go forward and backward | |
Doug Site Owner
Chopperhed Moderator
Doug Site Owner
| Subject: Re: idea to use a hydro tranny to chain drive to make an automatic March 8th 2013, 11:00 pm | |
Hydros aren't worthless. I'd love to have a couple.
It's a matter of application.[/quote]
i know, i meant for modding to go faster and stuff, heck u could use one to go offroading but not very fast lol. i like hyros nice to mow with
| Subject: Re: idea to use a hydro tranny to chain drive to make an automatic March 9th 2013, 12:14 am | |
It's a matter of application. i know, i meant for modding to go faster and stuff, heck u could use one to go offroading but not very fast lol. i like hyros nice to mow with[/quote] Some 34 years ago. I used to run a 444 Case Hydro. Had a 14 Kohler in it, Hydraulic Sleeve Hitch, Mechanial PTO clutch, And all the accessories. It had A hydro tiller and I could do wheelies with that thing all day, Throw the deck on and I could do donuts in the grass. It would top out around 15 Stock in High range, I want one | |
dylansrockinrigs Member
Age : 25 Join date : 2012-02-28 Points : 5035 Posts : 306 Location : Silk Hope N.C.
| Subject: Re: idea to use a hydro tranny to chain drive to make an automatic March 9th 2013, 12:59 pm | |
| A friend of mine has a mower with a hydro and we are lowering it and running a live axle with sprockets from each output on the hydro we are gonna put big sprockets on the hydro and small ones on the live axle and have a nice little gokart... also gonna hook the throttle up to the hydro peddle | |
Thunderdivine Veteran Member
Age : 30 Join date : 2013-03-18 Points : 4922 Posts : 618 Location : loxahatchee, florida
theswampmachine Member
| Subject: Re: idea to use a hydro tranny to chain drive to make an automatic September 15th 2013, 10:44 am | |
| What I would do it weld a rod directly off the input shaft and have it go Up to the top of the frame and have supports and what not on it then put a sprocket up at the top Of that shaft and a sprocket from on the motor then run a chain | |
Age : 25 Join date : 2013-04-05 Points : 4959 Posts : 661 Location : New Smyrna Beach,Fl
