| First Build | |
+4Stretch44875 TheRainbowBoxer richie thomas truckin42 8 posters | Author | Message |
Guest Guest
| Subject: First Build April 16th 2013, 8:47 pm | |
| This is my first true lawnmower build. It was originally a Gilson mower, a 52113A 48707 model with a 8 hp 190707 Briggs and Stratton. It has a Peerless transaxle, haven't looked very closely at the model of that really. I pretty much re-did everything on it. New frame, clutch set up, moved the motor to the back for extra weight, and of course...Bigger/better tires. |
| | | truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5505 Posts : 1070
| Subject: Re: First Build April 16th 2013, 8:51 pm | |
| - 8hp Kennworth wrote:
- This is my first true lawnmower build. It was originally a Gilson mower, a 52113A 48707 model with a 8 hp 190707 Briggs and Stratton. It has a Peerless transaxle, haven't looked very closely at the model of that really. I pretty much re-did everything on it. New frame, clutch set up, moved the motor to the back for extra weight, and of course...Bigger/better tires.
Cool sounds like a cool project. | |
| | | Guest Guest
| Subject: pics of it April 16th 2013, 8:56 pm | |
Last edited by 8hp Kennworth on April 16th 2013, 8:59 pm; edited 1 time in total |
| | | | richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6402 Posts : 1434 Location : east dublin georgia
| Subject: Re: First Build April 16th 2013, 9:15 pm | |
| looks good man, reminds me of the mud dragstirrs
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| Subject: Re: First Build April 17th 2013, 9:12 am | |
| Interesting set up. My guess is it would push pretty bad trying to corner without any weight on the front, but I bet it does a hell of a job going straight. | |
Age : 49 Join date : 2012-04-05 Points : 5703 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: First Build April 17th 2013, 10:07 am | |
| I bet not... If you look, he is sitting in front of the rear axle. Basically swapping engine weight for body weight. On advantage I see is set position is really low, and weight distributation is probably close to a stock mower. Long frame helps.
It may not be far off in handling compared to Jacob's RER | |
| Subject: Re: First Build April 17th 2013, 10:25 am | |
| I missed that..... You're probably right on the handling. | |
| | | Guest Guest
| Subject: steering April 17th 2013, 2:13 pm | |
| The weight distribution it perfect on it. I have had no problems with the steering at all |
| | | greener179 Member
| Subject: Re: First Build April 17th 2013, 2:29 pm | |
| Is it chain drive or are you using a belt? | |
| | | Guest Guest
| | | | redlinemotorsportts Moderator
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
| Subject: Re: First Build April 21st 2013, 11:22 am | |
| Those are some extremely aggressive tires. What are they? | |
| | | Guest Guest
| Subject: Re: First Build April 22nd 2013, 3:23 pm | |
| It does have bear claws on the back. And now the transaxle is shot because of quick shifting and gear grinding |
| | | Guest Guest
| Subject: DECOMMISSIONED April 25th 2013, 10:07 am | |
| Due to the transaxle breaking. This mower is going to be parked for a while |
| | | crafsmankiller Member
Age : 27 Join date : 2012-10-18 Points : 4895 Posts : 412 Location : livingston texas
| Subject: Re: First Build April 25th 2013, 3:45 pm | |
| i woulda put a big-ass twin on the back for a wheelie machine. that being said, will it pull a wheelie before the tranns blew? | |
| | | Blacksmith52 New Member
| | | | Sponsored content
| | | | | First Build | |
| Who is online? | In total there are 102 users online :: 0 Registered, 0 Hidden and 102 Guests
