| | Lift or lower Murray chain drive? | |
MurrayMudderr Member
Age : 28 Join date : 2012-11-24 Points : 4389 Posts : 38 Location : Iowa
| Subject: Lift or lower Murray chain drive? November 24th 2012, 10:54 pm | |
| I want to either lift or lower my new Murray chain driven mower i want to know which is easier. | |
| | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5217 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Lift or lower Murray chain drive? November 24th 2012, 11:13 pm | |
| they are probably just as hard, but since yours in chain drive(I sort of wish I started out with mine like that) all you should need to do is cut the brackets holding the bearings onto your frame and put a block between the cut area or to notch out part of the frame depending on what you want to do. Also your ging to have to probably extend the chain if you lift it and if you have a brake rotor on the rear axle you will have to move the brackets. and for Paint I dont really know, I personally like sticking with the stock paint or restore it to stock. | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5220 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
| Subject: Re: Lift or lower Murray chain drive? November 25th 2012, 7:22 am | |
| Lowering would be the easiest - the front axle can be solid mounted up in the chassis - the rear ( depending how low y want it) can be as easy as swapping a set of different smaller wheels on.
I had a mild mod MTD - wanted to do on the cheep with stuff i had around - i swapped pulleys, raised the front axle to the top of the chassis and bolted it solid - i took the tall stock back tires off and put some lower profile tires on ( used tubes ) - it lowered it a good couple inches just doing that.
I lowered the seat to the top of the chassis and cut the fenders to go lower also - it handled really good - felt solid and wasnt tipsy in the least going around corners. | |
| Subject: Re: Lift or lower Murray chain drive? November 25th 2012, 4:28 pm | |
| Well i guess first now i got to get to run it wont even turn over i found the clutch safety switch and put it back on and still nothing so i jumped it off the solenoid but then it wouldnt shut off | |
| Subject: Re: Lift or lower Murray chain drive? November 25th 2012, 4:38 pm | |
| did you try to bypass the solenoid?
If it didn't shut off with the key, I would suspect an ignition switch or wiring problem | |
| Subject: Re: Lift or lower Murray chain drive? November 25th 2012, 7:53 pm | |
| How would i go about lifting it up i saw one done by arild365 and idk how to go about doing the rear end part need help | |
| | | BlackMountian88 Member
Age : 25 Join date : 2012-09-08 Points : 4859 Posts : 399 Location : NH
| Subject: Re: Lift or lower Murray chain drive? December 10th 2012, 8:10 pm | |
| I find lifting easiest for the rear, you just add a spacer, and lowering easier for the front, cause you can usually get away with flipping the front axle right over! I lifted and lowered the tractor in my profile pic! | |
| Who is online? | In total there are 27 users online :: 0 Registered, 0 Hidden and 27 Guests
