| 01 murray hydrostatic drive trail/rockcrawler | |
+7Trcustoms 70craftsman redzz02 Ropertractor14 dangeroustoys56 Jamus hartman83 11 posters |
hartman83 New Member
Age : 35 Join date : 2011-01-22 Points : 5060 Posts : 9 Location : ohio
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5803 Posts : 511 Location : Southern WV
| Subject: Re: 01 murray hydrostatic drive trail/rockcrawler January 25th 2011, 10:14 am | |
| Welcome to the site. I have a 97 widebody auto that I mow with and my trail toy is a 01 widebody lt std. I haven't modded my mowing mower but have read that the auto tranny doesn't like higher speeds. If all else fails you could swap in a manual transaxle. However with all that front travel, you may want to keep it slow anyway. I don't think Fearlessfront swapped pulleys on his craftsman crawler. | |
| Subject: Re: 01 murray hydrostatic drive trail/rockcrawler January 25th 2011, 2:25 pm | |
| Hydros wont take abuse/mods - youll blow it up- hydros already run a 3" trans pulley , if you over heat them, theyll lock right up . Youd be better off getting a manual trans or going to a straight axle. | |
Ropertractor14 Member
Age : 110 Join date : 2010-02-23 Points : 5468 Posts : 84 Location : Nova Scotia, Canada
| Subject: Re: 01 murray hydrostatic drive trail/rockcrawler January 25th 2011, 4:08 pm | |
| We sped one of the hydro units up in a sears suburban to race, not too much but it did make it faster and the pump didn't have any problems.. But if it gets spun too fast it will have cavitation issues.. ruin the pump ect... | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: 01 murray hydrostatic drive trail/rockcrawler January 25th 2011, 5:07 pm | |
| WHAT EVER YOU DO DO NOT OPEN THAT CASE!!!!!!!!!!! SPRINGS AND INTERNALS WILL POP OUT AND YOUL BE FCKED not knowing where they go and you cant change the pulleys so you pretty much your stuck with the slow arse speed it has, but the hydros do take alot of beating you can tug a war, mud, and jump it, those things will take alot of abuse as long as you dont speed them up, another bad thing is they give you less ground clearance than a manual tranny, but if you get bigger tires you shouldnt have a problem | |
| Subject: Re: 01 murray hydrostatic drive trail/rockcrawler January 27th 2011, 5:51 am | |
| Almost have to laugh at the name on those shocks - 'delco pleasurizer' sounds like something from an adult bookstore- and thats a name GM came up with.....makes y wonder....
Cool setup - they should work for the purpose. If you could find a peerless 700 or right angle gear box - you could add a swing arm suspension to the rear as well- like an atv.
| Subject: Re: 01 murray hydrostatic drive trail/rockcrawler January 28th 2011, 2:48 pm | |
| Some rear engine riders come with the peerless 700's - those are the lower input pulley and side output sprocket type transmissions. Right angle gear boxes are a 1:1 box so you can run a straight rear axle, youd need a go kart clutch with that setup tho.
Hopefully soon ill be attempting to build my own right angle gear box out of an old lawntractor transmission have sitting outside my shed , i could use that instead of a 6 speed manual swapped into my MTD , and run a straight axle.
Tractor looks cool- i set up my old stock agway mud machine with large front tires and found a set of tall/big rear tires- sets pretty level now . | |
70craftsman New Member
Age : 32 Join date : 2010-12-20 Points : 5083 Posts : 1 Location : Stanwood, WA
Trcustoms Member
Join date : 2010-09-19 Points : 5406 Posts : 225 Location : Bear,De USA
noledroByrreK Member
Age : 30 Join date : 2011-01-14 Points : 5370 Posts : 252 Location : DFW Texas
DICE464 Member
Age : 28 Join date : 2010-07-30 Points : 5358 Posts : 129
Chunk Established Member
F150F250F350 Member
Age : 29 Join date : 2011-09-28 Points : 4862 Posts : 52 Location : Oskaloosa Iowa
| Subject: ha ha battery October 14th 2011, 2:43 pm | |
| I did the same thing I put a car battery in my green beast I starts that twin a lot beter and fits right in that 616. | |
