| Drive shaft idea's | |
blanket80 Member
Age : 29 Join date : 2010-11-10 Points : 5290 Posts : 128 Location : Scottdale, PA
| Subject: Drive shaft idea's January 29th 2012, 1:53 am | |
| I had an idea that came to my mind, that would eliminate belt slippage. My thought was, put a horizontal shaft engine in a tractor. Then take a trans axle and turn it so that the input shaft was facing the engine shaft. ( engine l--- --l transaxle). Then make a drive shaft to connect them. A plus with this set up is it would be a 1-1 ratio. Because the trans would spin just as fast as the engine. The only big problem is making a clutch.. What do you guys think? | |
| | | W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5248 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Drive shaft idea's January 29th 2012, 10:02 pm | |
| You could do that but why not just use a shaft driven lawn tractor like some cub cadets? | |
| | | blanket80 Member
| Subject: Re: Drive shaft idea's January 30th 2012, 3:14 pm | |
| I dont like beating good cub cadets, they are worth money, and starting to get rare. I want one to pull with though.
| Subject: Re: Drive shaft idea's January 31st 2012, 5:58 am | |
| Best way to do that would be to use a RAGB - run the driveshaft to the RAGB - then to the transmission - youd need some sort of clutch because w/o one it would constantly be engaged . Then a 'normal' top input type trans can be used. A drawback would be ujoint failure unless constantly serviced.
Cubs have thier clutch mounted to the motor then to the driveshaft - from what i take theyre pretty complicated to set up correctly.
In all my years of going thru a swamp- super thick mud and water ( up to the floorbords) - i never had any belt slippage, same belt that came on the tractor when i bot it - slippage is caused by the belt wearing too rapidly. | |
| Who is online? | In total there are 30 users online :: 0 Registered, 0 Hidden and 30 Guests
