 Shaft vs Belt Drive
coldroadbear
Shaft vs Belt Drive Empty
PostSubject: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeMay 29th 2012, 11:40 am
Witch would be better I am wanting to build a off road tractor and would like for it to be diesel but from what i am seeing i can only get on with a shaft can you make a shaft drive put out speed or can i get a diesel with a belt drive
thanks
Coldroadbear
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeMay 29th 2012, 7:14 pm
I dont think you would be able to make a diesel belt drive just because it would be really hard finding a Vertical shaft Diesel Engine. but it would be alot better with shaft drive because there is no belt slippage and you wont have to worry about that. If your using a diesel you have to think of that your going through and think of making a meter for your fuel so you dont run out. If you Run out of fuel its sort of annoying to prime them, and if you flood a diesel you'll have fun getting the water out. Ive thought of a diesel for trail riding(Fuel efficiency and TORQUE), nothing through mud pits/water holes just because its a little harder to get them cleaned out. Plus Diesels are expensive.
http://www.stat10.tk/
coldroadbear
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeMay 29th 2012, 8:10 pm
I know about the diesel and that stuff but how would you set up the shaft driven tranny just open it up and switch the gears around or what
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeMay 29th 2012, 11:41 pm
Shaft drive might be hard if you dont already have a tractor that is shaft drive, if you have a tractor that is belt driven right now you would have to make the drive shaft, I would make the drive shaft your making fit the original shaft the trans pulley goes on and put a couple u-joints in it or find a high speed gearbox that has the output 90 degrees from the input and is a 1:1 ratio and run that to your engine(you would need another u-joint still). It would be alot of work and you would need a welder but if you have an old cub cadet shaft drive it would be fairly easy, just mount the drive shaft to the crank(make a sleeve for it) or to the flywheel(I don't know how its done but there are videos of builds on youtube with the drive shafts attached to the flywheel).
coldroadbear
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeMay 30th 2012, 10:42 am
Well i am not trying to make a belt drive in to a shaft drive. i mainly wanted to know what has to be done to a shaft drive in order to make it have some speed. i mean i don't need to to do 90 in the woods. As far as a diesel it would sound better in the woods lol.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeMay 30th 2012, 7:59 pm
Ooh that would be fun...umm probably tearing the transmission apart is the best way to do it but I dont know where you could get gears. Or trying to mount the motor and attach a high speed gear reduction box on and turn it around so you use the output as an input and mount your engine a little forward at the same time.Or put a two stroke snowmobile gasser in it and get it ripping upto 7,000rpm all day:P
coldroadbear
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeJune 4th 2012, 12:16 am
lol true and thanks for the help
Hillbilly Homer
Hillbilly Homer
PostSubject: Re: Shaft vs Belt Drive   Shaft vs Belt Drive Icon_minitimeJune 4th 2012, 12:57 am
Do you have a specific tractor in mind?
Shaft vs Belt Drive
» can a 1/4" make a difference for a drive belt?
» Shaft Drive Ideas?
» Need help finding a drive belt for a john deere 60
» Old mtd drive belt questions
»  Briggs 14 hp vert shaft IC engine Starter drive gear problems
