 can a 1/4" make a difference for a drive belt?
garvy
can a 1/4" make a difference for a drive belt? Empty
PostSubject: can a 1/4" make a difference for a drive belt?   can a 1/4" make a difference for a drive belt? Icon_minitimeSeptember 16th 2016, 3:53 pm
I bought a mower from a guy that said it needed a belt and he had one. I just took his word for it and removed the old one then put the new one on. well the trans doesn't disengage when I push the clutch in. I took it off and compared the two and the old one has a slight bit of slack so I put it back on and same thing. so now I have looked up both belts they are listed as 95". I looked in the owners manual that says is the same model as mine and looked up that part number it is 95". then I found a thread on the internet for a tractor with the same model number as mine and their "pro" gives a different part number and when I look that up it is
95 1/4".
» How i can make or buy a guard or cover for my belt?
» Old mtd drive belt questions
» Shaft vs Belt Drive
» whats the drive belt size for a bolens stg 125
» Make your own front 4 wheel drive axle?
