| B&S flathead crank compatability? | |
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5803 Posts : 511 Location : Southern WV
| Subject: B&S flathead crank compatability? January 9th 2013, 6:41 pm | |
| Hey guys, anyone know if the crankshafts will swap between vertical and horizontal motors? I have a 10hp generator motor with the goofy tapered crank, and I have a 11hp vertical shaft mower motor that needs cylinder work. Think it's possible to take the crank out of the 11hp that has a dtraight keyed shaft, and put it into the 10hp horizontal generator motor? Other than the tapered crank, the 10hp is in great shape, I want to put it on a walk behing tractor. | |
| | | Doug Site Owner
| Subject: Re: B&S flathead crank compatability? January 9th 2013, 7:24 pm | |
| You would have to look up part numbers for each crank and see if they are the same. Since they are different Hp though im gonna guess they arent. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: B&S flathead crank compatability? January 9th 2013, 8:26 pm | |
| Part numbers aren't the same even on same hp ratings though I know many parts swap that aren't identical numbers. The numbers is what I checked first though. | |
| | | Kel Member
Join date : 2013-03-06 Points : 4356 Posts : 75 Location : New Franken
| Subject: Re: B&S flathead crank compatability? March 22nd 2013, 7:03 pm | |
| Longer rod, makes for a .110 piston pop up. After milling it'll look like a dome piston. 12.5 stroker engine. This will be the 5th one I built. *hint, adjust the timing via flywheel key. *4 degrees. This one will go in my Enduro mower. 0 to 60. 1/3 finished with it. Kel[img] [/img] | |
| Who is online? | In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests
