| Losing oil thru crank case vent on 17.5 Briggs Any ideas why? | |
Boogger31 New Member
Age : 44 Join date : 2013-01-01 Points : 4362 Posts : 20 Location : Gaylord mi
| | | | Chopperhed Moderator
| | | | Doug Site Owner
| | | | Doug Site Owner
| Subject: Re: Losing oil thru crank case vent on 17.5 Briggs Any ideas why? January 12th 2013, 12:47 pm | |
| Check to see if the oil smells like gasoline - if it does, change the oil FIRST, then either rebuild or super clean the carb - usually if the oil is over filled, its due to gasoline leaking into the oil ( thru the valves) because the float bowl sticks and lets gas flow even when its off. If the tractor is run with thinned oil, itll melt the berings and blow the motor.
Id also suggest a fuel line shut off valve. | |
