| Anyone every have issues with the seal on the crank shaft leaking oil? | |
theswampmachine Member
| | | | greener179 Member
Age : 54 Join date : 2010-02-10 Points : 7070 Posts : 1726 Location : Florida, USA
| Subject: Re: Anyone every have issues with the seal on the crank shaft leaking oil? January 19th 2013, 6:12 pm | |
| Wear and tear - old age - motor sits alot - any number of things cause them to wear out.
I bot a MTD for $25 years ago came with a 80's LT parts craftsman , rebuilt MTD deck and a spare parts motor. The motor on the MTD ran, shortly after i noticed it leaked oil all over the place , needed a new lower crank seal.
Spent all of $5 on a new seal and pan gasket, carefully took the pan off - checked things out in the motor , carefully pried out the old seal and reinstalled the new seal ( with a large socket that fit it and tapped it gently in) - had it all back together and back on the tractor in about a 1/2 hr.
Very easy job to do, after the motor is off the tractor. | |
| | | Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5248 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| | | | Sponsored content
| Who is online? | In total there are 13 users online :: 0 Registered, 0 Hidden and 13 Guests
