| Mastercraft Off road project | |
+28MowBandit redlinemotorsportts motorizedeverything Doc Sprocket mudmonkey06 tractorboy567 xxXMowerdudeXxx richie thomas RCG Thunderdivine truckin42 THE MTD GUY Doug Murray modder Stretch44875 Tractor Man Jeff CornishMorgan Junkstarbuilds craftsman rider Trikahilux Bandit1 dylansrockinrigs dangeroustoys56 greener179 muddstir W1ldyOvvnZ Chopperhed TennesseeCowboy 32 posters | |
motorizedeverything Member
| | | | truckin42 Veteran Member
| | | | Doc Sprocket Site VIP
| Subject: Re: Mastercraft Off road project Tue May 07, 2013 8:31 pm | |
| Oh, that's just a kick in the teeth. Incompatible paints, or did something else go sideways on you?
Web looks good. Reverse mask? | |
| | | Chopperhed Moderator
| Subject: Re: Mastercraft Off road project Tue May 07, 2013 9:26 pm | |
| Tremclad Clear over tremclad Gloss black. The gloss blacks needs a huge flash time apparently. I threw the Candy over it just so see how it would look. The Result. I looked at it, not real happy. I'll see what else I can come up with. | |
| | | | richie thomas Veteran Member
| Subject: Re: Mastercraft Off road project Tue May 07, 2013 9:43 pm | |
| paint looks really good man, can you explain to me how you did it, ive been wanting to pinstripe one of mine, but i aint had any good ideas on how to do it | |
| Subject: Re: Mastercraft Off road project Tue May 07, 2013 10:34 pm | |
| The paint is the issue. I screwed up in using tremclad. Proper prep is always the issue, even when dealing with spraybombs
tremclad is fine for frames.
This sample is a combination of tremclad black over duplicolor high performance wheel paint, under duplicolor clear.
Paint the whole hood the shiniest silver you can, I used duplicolor high performance wheel paint, aluminum.
Throw a coat of clear over it to seal it. duplicolor gloss clear.
I layed out the web using 1/4`wide masking tape over the aluminum clear coat.narrow masking tapes can be bent as they are layed down. It was all done free hand.
Once I had it all layed out. I sprayed gloss black over everything. Heres where the tremclad comes in Then I pulled all the masking tape.
That left me with the silver web.
Then I sprayed clear over it, which is where this paint job messed up.
the black wasn;t dry enough, i sprayed too soon.
Then I threw a coat of duplicolor metelcast red over top to give me the blood red lines. another coat or three of clear and it would have been kickass.
Also i`ve found that throwing the candy colors over black tends to give the black parts a slight tinge of the candy color..
| | | | redlinemotorsportts Moderator
| Subject: Re: Mastercraft Off road project Wed May 08, 2013 11:25 am | |
| Ok, your method was exactly what I expected. It's too bad it took a dump on you, as it would have been quite nice. I've had enough paint jobs go south that I never mix types/brands of paint anymore. There's some combos you can get away with, but I HATE redoing stuff, so I don't chance it.
Guess you have to sand/strip the whole schmeer now? | |
| Subject: Re: Mastercraft Off road project Wed May 08, 2013 2:53 pm | |
| - Doc Sprocket wrote:
- Ok, your method was exactly what I expected. It's too bad it took a dump on you, as it would have been quite nice. I've had enough paint jobs go south that I never mix types/brands of paint anymore. There's some combos you can get away with, but I HATE redoing stuff, so I don't chance it.
Guess you have to sand/strip the whole schmeer now? Poly stripper is a wonderful thing, It should only take a couple of hours to strip the paint, plus a couple more weeks of alternating paint coats and drying time. I'm going to stick to all duplicolor paints this time. Twice as much money, half the work. | |
| Subject: Re: Mastercraft Off road project Sun Jun 02, 2013 5:50 pm | |
| Finished the paint. Pretty much finished now, except for the fuel tank, heat shield for the exhaust, and possible wheelie bars. | |
| | | greener179 Member
| | | | Thunderdivine Veteran Member
| Subject: Re: Mastercraft Off road project Sun Jun 02, 2013 7:38 pm | |
| I was just thinking about this rig today. glad to get a update, I wonder how its going to be in the dirt. | |
| Subject: Re: Mastercraft Off road project Sun Jun 02, 2013 9:01 pm | |
| I have the heat shield figured out, the piece is cut, need a few minutes with the hole saw.
The fuel tank has a bottom end, and fuel outlet welded in, but needs a filler neck, top end, and vent.
Wheelie bars are next after that. And I almost forgot, I have a piece of poly cut to fit the cavity on the nose.
Trying to decide what to do with it.
On a side note, I put a new bumper and grill on the van today, cost me 150 bucks. Bitch is on these units, the rad support is a structural member, I had tom use a hydraulic jack to pull out the rad support.
| | | Doug Site Owner
| | | | MowBandit Member
Age : 28 Join date : 2013-03-15 Points : 4746 Posts : 477 Location : Haddock,Georgia
| | | | Ariens YT11 Established Member
Age : 27 Join date : 2012-10-31 Points : 5161 Posts : 745 Location : The Wyo-Braska Panhandle
| Subject: Re: Mastercraft Off road project Mon Jun 03, 2013 8:56 pm | |
| worked on the heat shield for the exhaust.
also, fixed a pto bearing for a guy at work with with an old Craftsman, that he wont sell.
Age : 25 Join date : 2013-04-05 Points : 4959 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: re Tue Jun 04, 2013 11:09 am | |
| Cool mower I guess, not big enough for me! | |
| Subject: Re: Mastercraft Off road project Tue Jun 04, 2013 1:05 pm | |
| chopper, this is probably my favorite build on the whole site, everything on it is done to exceptionally high standards and you are truly a master when it come to this, i can not wait until we get video of this thing driving around | |
| Subject: Re: Mastercraft Off road project Tue Jun 04, 2013 8:20 pm | |
| bendy pipe is expensive, but in cases like yours is a hole lot easier to get that instead of bending pipe. cool guard. | |
| Who is online? | In total there are 8 users online :: 1 Registered, 0 Hidden and 7 Guests RichieRichOverdriveMost users ever online was 412 on Sat Jan 07, 2023 6:59 am |
