| Mastercraft Off road project | |
+28MowBandit redlinemotorsportts motorizedeverything Doc Sprocket mudmonkey06 tractorboy567 xxXMowerdudeXxx richie thomas RCG Thunderdivine truckin42 THE MTD GUY Doug Murray modder Stretch44875 Tractor Man Jeff CornishMorgan Junkstarbuilds craftsman rider Trikahilux Bandit1 dylansrockinrigs dangeroustoys56 greener179 muddstir W1ldyOvvnZ Chopperhed TennesseeCowboy 32 posters | |
| Subject: Re: Mastercraft Off road project June 4th 2013, 9:20 pm | |
| bendy pipe is expensive, but in cases like yours is a hole lot easier to get that instead of bending pipe. cool guard. | |
| | | Chopperhed Moderator
| Subject: Re: Mastercraft Off road project June 4th 2013, 9:31 pm | |
- bendy pipe is expensive, but in cases like yours is a hole lot easier to get that instead of bending pipe. cool guard.
That piece cost me 6 bucks. | |
| Subject: Re: Mastercraft Off road project July 9th 2013, 8:24 pm | |
| Its been a while since the lastb update, and I have nothing g to show you right now.
I've hung up on scrounging an appropriate filler neck and cap for the fuel tank.
It's the last niggly little piece of the build, and I haven't been able to find a good weld in unit that is free/ cheap.
I tried cutting one out of a stock Honda clone tank but it didn't work out. I need some thing smaller. | |
| Subject: Re: Mastercraft Off road project August 5th 2013, 5:29 pm | |
| Fires right up, as a brand new engine should. Seems to be geared too tall, have to rev the nuts off it to get it rolling. I'm betting it would hit the 60 mph top end, but it will take time. | |
| Subject: Re: Mastercraft Off road project August 5th 2013, 6:08 pm | |
| But, does it blend? Just kidding lol. I like the little features that you have like the diamond plate and the red hubs. Good attention to detail. | |
| | | | k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5368 Posts : 1135 Location : Southern Florida
| | | | Thunderdivine Veteran Member
| | | | Stretch44875 Administrator
Age : 49 Join date : 2012-04-05 Points : 5698 Posts : 959 Location : Mansfield, Ohio
| Subject: Re: Mastercraft Off road project August 6th 2013, 3:35 pm | |
| Yes, it's a simple centri clutch jackshaft setup. One forward, no reverse.
Ratio changes require removing the chain guard, and changing out the jackshaft sprocket, and chain. I can go up about 3/4" in radius on the JS sprocket to get a quicker ratio.
I built a baffle for the exhaust, it was way too loud and bogging too much. So far its working well | |
| Subject: Re: Mastercraft Off road project August 6th 2013, 6:34 pm | |
- Whats the turning percentage on it?
Same as the stock 350 warrior.. I tried to keep the geometry as close to stock as I could. | |
| Who is online? | In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests
