 dirtbike tires on mower
greener179
greener179
dirtbike tires on mower Empty
PostSubject: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 5th 2012, 2:51 am
i read about poeple putting dirtbike tires on the front but i want to put some on the back any ideas
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 5th 2012, 11:35 am
get a dirt bike tire, get a welder, weld the bearing solid, drill out a hole for it to fit on your transaxle then weld it solid. seems stupid but I think it could work.
http://www.stat10.tk/
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 5th 2012, 2:03 pm
that would work but how do i get the keyway in it
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 5th 2012, 3:19 pm
You would need a keyway broach tool.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 5th 2012, 9:06 pm
so is it worth the work?
matthew sidor
matthew sidor
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 5th 2012, 10:19 pm
the traction is gonna be insane way better than any atv tire. i think its worth it if u can do it
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 12:54 am
i might have thought of a idea what if i take the sprocket off the rim and put a thick piece of steel instead bolt it back to the rim and drill 4 holes in the piece of steel matching a 4 bolt bolt hub
matthew sidor
matthew sidor
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 1:10 am
make the hub bolt pattern fit the sprocket bolt pattern. bolt it right on. that seems like a good idea
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 1:54 am
ya that will work just looking for some dirtbike tires/rims now im hoping it works good because i wanna go big or go home
matthew sidor
matthew sidor
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 2:25 am
dude post some pics if u get it done
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 2:44 am
One thing I would look for is a cheap keyway broach tool, I know the kits are a fair bit of money
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 3:09 am
ok i will be on a look out for one of those tools but does anyone know where i could get the two rear dirtbike tires and rims for a decent price
matthew sidor
matthew sidor
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 1:48 pm
go to a junkyard or scrapyard u could probably find 2 for cheap
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 2:32 pm
dont really got any junk yards around here with dirtbike atv or motorcycle stuff
matthew sidor
matthew sidor
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 2:40 pm
well that really sucks and u dont have a scrapyard
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 3:38 pm
we got normal junk yards with only cars and a place to take scrap metal back but you cant buy anything from them
greener179
greener179
PostSubject: Re: dirtbike tires on mower   dirtbike tires on mower Icon_minitimeAugust 6th 2012, 9:42 pm
well in till i find dirtbike rims and tires i put duals on
» What are the best Mower tires
» Mudding Mower Tires
» ATV TIRES ON A PLANE JANE RIDING MOWER RIM?
» 97 Murray wide body WITH PICs!
» Best pulley ratio to make mower spin the tires
