| Mudding Mower Tires | |
+7Doug Webmaster Chopperhed redlinemotorsportts truckin42 richie thomas 14raptor14 11 posters |
14raptor14 New Member
Age : 24 Join date : 2013-03-15 Points : 4291 Posts : 15 Location : New Jersey
| Subject: Mudding Mower Tires April 22nd 2013, 9:14 pm | |
| Do you guys think the outer tire or current inner tire is best for muddin? | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6400 Posts : 1434 Location : east dublin georgia
Guest Guest
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5503 Posts : 1070
| Subject: Re: Mudding Mower Tires April 22nd 2013, 10:09 pm | |
| If you run those tires you should flip them backwards (reverse tread) and see witch way works best. Sounds funny but I've seen big improvement before. | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5254 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Mudding Mower Tires April 22nd 2013, 10:20 pm | |
| They would both work well,
Good open blocks pretty much self cleaning if you can spin them fast enough.
The taller tire will dig deeper and get your tractor through deeper crap. | |
| Subject: Re: Mudding Mower Tires April 23rd 2013, 7:26 am | |
| Ha! Sounds interesting and I've never seen it. Ill try it. | |
Webmaster Webmaster
Age : 14 Join date : 2010-02-09 Points : 5735 Posts : 332 Location : Here!
| Subject: Re: Mudding Mower Tires April 25th 2013, 5:40 pm | |
| if they both hold air, and have decent tread, the you can't go wrong either way. Like Copperhed mentioned, a taller tire is the only real way to "lift" your mower, and get more distance between your transaxle and the ground. Bigger tires will also make it go a little faster, and will be more stressful on the trans, but you tires look narrow, which is perfect.... I never liked wide tires.. they just float and spin on the top of the mud. Narrow tires dig down to solid ground. Look at the big ass farm tractors... Tall, narrow tires... those things rarely get stuck. | |
| Subject: Re: Mudding Mower Tires April 25th 2013, 5:44 pm | |
| Woah fearless is actually posting lol yea i used front blaster tires tall and skinny. | |
Doug Site Owner
| Subject: Re: Mudding Mower Tires April 25th 2013, 6:02 pm | |
| Anything is better than turfs. I would go with the one that has the deepest tread. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: Mudding Mower Tires April 25th 2013, 8:02 pm | |
| - Doug Fackler wrote:
- Anything is better than turfs. I would go with the one that has the deepest tread.
Yeah turfs dont do good. I use like 24x6x13s inch tires for mine tall and skinny. | |
khsindian2011 New Member
Age : 31 Join date : 2013-06-20 Points : 4184 Posts : 8 Location : florida
Age : 25 Join date : 2013-04-05 Points : 4962 Posts : 661 Location : New Smyrna Beach,Fl
Age : 37 Join date : 2013-07-02 Points : 5019 Posts : 731 Location : Logan Ohio
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5371 Posts : 1135 Location : Southern Florida
| Subject: Re: Mudding Mower Tires July 3rd 2013, 12:14 am | |
| The outer ones have a better v tread and are taller so I'd go with the outers | |
