| Manual Rack | |
dagr8tim Member
Age : 48 Join date : 2012-01-01 Points : 4938 Posts : 194 Location : Columbus, Oh
| Subject: Manual Rack January 19th 2012, 8:44 am | |
| Anyone ever think about taking a manual rack from say a Geo Metro and cutting it down for use on a tractor? | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4933 Posts : 208 Location : Tennessee
| | | | dagr8tim Member
| Subject: Re: Manual Rack January 19th 2012, 1:53 pm | |
| - AcreFarm wrote:
- Not tractor, but I don't see why it wouldn't work on a modified LT
This is a Dodge K-car power rack (not powered) attatched to a front axle made of square tubing that uses spindles from a Massey GT That's sorta what I'm thinking. I wonder how it performs. | |
| | | AcreFarm Member
| Subject: Re: Manual Rack January 19th 2012, 2:12 pm | |
| It does very well. The only problem I have is the space for a drag link was very limited... too small for auto parts. I've tried regular GT type ends, and heim joints and they both break after a while. | |
| | | goesman Member
Age : 45 Join date : 2012-01-18 Points : 4850 Posts : 119 Location : Salem, Mo.
| Subject: Re: Manual Rack January 19th 2012, 7:57 pm | |
| I have a rack that i bought at a swap meet many years ago. Its real small and very strong, the VW dune buggy guys use them. wish i could remember what brand it was. some day it will make it on my tractor. | |
| Subject: Re: Manual Rack January 21st 2012, 8:32 am | |
| The only real way to see if anything works is to try it - called fabrication. Id go to a junkyard, and buy one - im sure they cant be that much and just experiement with it - that one guy used a rack from a golf kart .
To bypass the power part ( or the pump) - just fill the rack with power steering fluid and cap the holes where the pressure lines go in .
Tractors dont really need alot of tight tolerances , unless its involved with speed, for general trail riding , if the rack ends were cut down and rewelded it shouldnt make a difference.
If someone to really go wild- use hydraulic or electric steering - like on monster trucks or rock buggies - what about a linear actuator? Small hydraulic ram?
Just depends what your budget is. | |
| | | goesman Member
| Subject: Re: Manual Rack January 21st 2012, 8:44 am | |
| My tractor originally had hydraulics on it that run off the trans. I have thought a many a times about making hydraulic steering. | |
| | | dagr8tim Member
| Subject: Re: Manual Rack January 21st 2012, 11:42 am | |
| - dangeroustoys56 wrote:
- The only real way to see if anything works is to try it - called fabrication. Id go to a junkyard, and buy one - im sure they cant be that much and just experiement with it - that one guy used a rack from a golf kart .
Just depends what your budget is. I agree with you, but there's no point in reinventing the wheel if it's known that it will not work. Also, if you get a rack from say a 3 cylinder Geo Metro, they are manual without having to do anything special. Maybe I'll start trolling the JY's. | |
| | | cj8 New Member
Join date : 2011-08-16 Points : 4854 Posts : 11 Location : Kansas City, Mo
| Subject: Re: Manual Rack February 4th 2012, 7:22 am | |
| I used a manual steering rack on my monster mower. With 35" tires you can steer it with one finger. Golf cart parts are way too expensive. Rack was $29.00 at salvage yard. I shortened the tie rod ends as much as I could. The rack ended up about 36" in length. may be too long for a mower. | |
| | | | | Manual Rack | |
| Who is online? | In total there are 37 users online :: 0 Registered, 0 Hidden and 37 Guests
