| Hows direct drive in the mud? | |
RompinRedneck Member
Age : 31 Join date : 2012-01-01 Points : 4756 Posts : 41 Location : CT
| Subject: Hows direct drive in the mud? January 3rd 2012, 3:57 am | |
| The title says it all, how is direct drive (drive wheel+friction disk) and I am really questioning how this will hold up in the mud compared to the normal pulley+belt setup. | |
| | | redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: Hows direct drive in the mud? January 3rd 2012, 11:19 pm | |
| ..... what are you trying to build that is friction drive???? its not going to hold up for anythng in the mud | |
| Subject: Re: Hows direct drive in the mud? January 4th 2012, 1:17 am | |
| - redzz02 wrote:
- ..... what are you trying to build that is friction drive???? its not going to hold up for anythng in the mud
I got this snapper front engine for $20. Just wondering if it would hold up to anything. Now that I know they are less than desirable, It is a parts mower. Thanks man. | |
| Subject: Re: Hows direct drive in the mud? January 8th 2012, 11:31 am | |
| Snapper mowers have advantages and disadvantages - the biggie is the friction drive - they have to be set correctly to work most efficent , they do tend to flatten, crack and wear out with use as well.
Id give it a no for mud/water , since it should be clean for best driveability - you could do a trans swap and ditch the friction drive. | |
| Who is online? | In total there are 44 users online :: 0 Registered, 0 Hidden and 44 Guests
