| Direct Steer | |
akcender Member
Age : 29 Join date : 2011-12-04 Points : 4822 Posts : 46 Location : Toronto, Ontario, Canada
| Subject: Direct Steer December 14th 2011, 8:20 pm | |
| does anyone have a diagram for a direct steer system. A video would be great | |
| | | AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4938 Posts : 208 Location : Tennessee
| Subject: Re: Direct Steer December 14th 2011, 9:52 pm | |
| This is how my tractor is currently set up, it works good, but I'm thinking of revamping it this spring. I may change it to a center pivot point, like this. | |
| | | akcender Member
| | | | AcreFarm Member
| Subject: Re: Direct Steer December 14th 2011, 10:58 pm | |
| It doesn't hurt clearance at all. If you look at my avatar pic you can see there's no parts of the steering hang below the axle. Here's another pic for you... I couldn't go straight thru the frame with the steering, so I used a 1/2" u-joint to get everything to line up. I added a couple greasable sleeves to hold it all steady. | |
| | | akcender Member
| Subject: Re: Direct Steer December 15th 2011, 8:10 am | |
| - AcreFarm wrote:
- It doesn't hurt clearance at all. If you look at my avatar pic you can see there's no parts of the steering hang below the axle.
ok right on, thanks for the help man | |
| | | | | Direct Steer | |
| Who is online? | In total there are 99 users online :: 0 Registered, 0 Hidden and 99 Guests
