| Troy Bilt with Pedal Drive/Vari Drive Setup (Best Way to Speed Up?) | |
Papa Shaun New Member
| Subject: Troy Bilt with Pedal Drive/Vari Drive Setup (Best Way to Speed Up?) November 13th 2016, 9:47 am | |
| I"ve got a 2002 Troy Bilt Lawn Tractor, that features the vari drive system, but is also a pedal drive. From what I understand, swapping the Transmission Pulley to a smaller size, will not help in speeding up the mower, due to the fact that the variable speed pulley controls the mower speed, and the transmission pulley is primarily used for forward/reverse. This thing has a crazy belt size, the upper drive belt on the transmission pulley is like 5/8" x 41.5".....while the lower drive belt is like 5/8" x 90.5." I"ll include a link at the bottom showing how tension on the lower belt is what primarily drives the mower.....My question....... would doing an engine pulley swap really help in speeding up the mower any at all, without trying to modify the trans anyway? Reason I ask, I'm hesitant about trying to mess with this variable speed pulley in any form, since a replacement is like $100 everywhere I look. In addition, changing belt sizes worries me, since the variable speed pulley is basically a double pulley in a sense. I appreciate any help, and I'm not looking to really change the trans at this time. Here is a link I found on Youtube showing how this system operates, thanks: https://www.youtube.com/watch?v=KFar2Ez10Wk | |
| | | Doug Site Owner
| | | | MatthewD Veteran Member
| Subject: Re: Troy Bilt with Pedal Drive/Vari Drive Setup (Best Way to Speed Up?) November 13th 2016, 11:55 am | |
| You can change either. The front may be easier though, just buy a V belt pulley with a 1" bore of whatever size, depending on what speed you want. Remember, Engine Pulley (Driver) - Bigger = Faster Transaxle Pulley (Driven) - Smaller = Faster Hope this helps! | |
| | | | Sponsored content
| Who is online? | In total there are 78 users online :: 0 Registered, 0 Hidden and 78 Guests
