Performance Tool Scissor Jacks W1600
https://www.summitracing.com/parts/WMR-W1600I am using this jack to lift riding lawn mowers and lawn tractors.
I needed something with a wide base, short in height, that could lift 12" high in the air as I shoved either wood blocks or cinder blocks (CMUs) under the rear axle to work on the machine. The mowers only weigh between 400-1000 pounds, but, even with the small riding mowers it can be a hassle lifting them up high enough to block them to change a tire.
Not as stable as a floor jack, but, it does not weigh 50-80 pounds, which if you bring it along for a ride, makes a big difference in carried weight on a 400-1000# machine.
I put an adapter on mine so I can easily use an impact driver (1/4" Ryobi - maybe 30 ft pds?) or 1/2" ratchet to quickly raise and lower it.
TONDA Scissor Jack Adapter for 1/2 Inch Impact Wrench or 13/16 Inch Lug Wrench, Scissor Jack Drill Adapter for Impact Drills Socket Automotive Jack RV Trailer Leveling Jack
https://www.amazon.com/gp/product/B0793PJBB6It works well doing the front too and lifting at the pivot point.
