| mud monster | |
greener179 Member
| Subject: mud monster November 13th 2012, 1:25 pm | |
| i have been watching your guys builds for a while now so i thought i would start my own.Im starting with a ranchking by mtd with a 12hp powerbuilt.The plan is to put a peerless 700 in it with a go kart axle and direct steer.Also a custon front axle and will be running 27 inch kenda executioners in the back and 25 inch dunlops if the front. | |
Junkstarbuilds Administrator
Age : 48 Join date : 2012-07-03 Points : 4820 Posts : 236 Location : Fort Stewart Georgia
| Subject: sounds good November 15th 2012, 8:47 am | |
| Sounds like you got it all figured out...are you going to make videos and post them to youtube? Some of us like to watch builds, some are satisfied with pictures...
greener179 Member
| Subject: Re: mud monster November 15th 2012, 9:11 am | |
| just pictures i have no way to make videos sorry guys there will be a test run video at the end tho | |
| Subject: thats cool! November 15th 2012, 9:15 am | |
| - greener179 wrote:
- just pictures i have no way to make videos sorry guys there will be a test run video at the end tho
No worries, good luck on your build, and will be looking forward to the test run! If you ever need a second opinion feel free to hit me up, Im on all the time. I dont always have the right answer but I wont leave you hanging.. | |
greener179 Member
| Subject: Re: mud monster November 15th 2012, 9:22 am | |
| will do im picking up one maybe two of the main parts this weekend the peerless 700 i know im getting for sure thiss weekend | |
greener179 Member
| Subject: Re: mud monster November 16th 2012, 12:45 am | |
| Well talk to the dude and im getting the rer engine rider with the peerless 700 in it this weekend for a little 6 gallon air compressor that wont hold air and 5 dollars sound like a good deal? | |
| Subject: Sounds good to me.. November 16th 2012, 3:57 am | |
| - greener179 wrote:
- Well talk to the dude and im getting the rer engine rider with the peerless 700 in it this weekend for a little 6 gallon air compressor that wont hold air and 5 dollars sound like a good deal?
sounds like a deal to me...have you have it a look over? I try to avoid money pits. Meaning if you might have to spend a lot of cash to fix it, it might not be worth it. Send pics of before and after! | |
greener179 Member
| Subject: Re: mud monster November 16th 2012, 9:00 am | |
| im just taking the peerless 700 out of it and selling the rest to my brother | |
| Subject: theres value in a good 700 November 16th 2012, 9:04 am | |
| - greener179 wrote:
- im just taking the peerless 700 out of it and selling the rest to my brother
Well you very well know the value of a good 700! plenty of people on this forum would gladly make an offer..lol! I have a hydrostatic I could sell, but no one wants those! | |
greener179 Member
| Subject: Re: mud monster November 16th 2012, 9:08 am | |
| ya when using the peerless 700 on my project should i pput a jackshaft in so it takes the strees off of it? | |
| Subject: Jack shafts November 16th 2012, 9:19 am | |
| - greener179 wrote:
- ya when using the peerless 700 on my project should i pput a jackshaft in so it takes the strees off of it?
Jackshafts are used for many different reasons, It really doesnt matter on the stress factor I dont think.. Use one if things dont "line up" or sometimes people make several size ratios on the jack shaft and keep one size on the axle, that way you only have to exchange jackshafts to get different driving conditions..(that make sense?) For the most part, most racing mowers ive seen have a tiny gear on the output drive running to a big gear on the axle..Only in a few set ups have I seen them use a jack shaft.. | |
greener179 Member
| Subject: Re: mud monster November 16th 2012, 3:15 pm | |
| ok i wont then thanks for the info just got to figure out which sprockets to use on the axle and gear box then | |
chevyMudMower69 New Member
Join date : 2012-07-17 Points : 4487 Posts : 1 Location : burlington iowa
| Subject: Re: mud monster November 16th 2012, 3:19 pm | |
| [quote="greener179"] yeh iwouldnt use a jackshaft
greener179 Member
| Subject: Re: mud monster November 21st 2012, 1:55 pm | |
| the project is still going im just collecting all the parts i need before i start building.Does anyone know what size sproket i should use on the axle i will be running a 1:1 ratio to the peerless 700 and the gear box has a 8 tooth sprocket. Im wanting to go around 20mph | |
| Subject: Im not an expert November 21st 2012, 1:59 pm | |
| - greener179 wrote:
- the project is still going im just collecting all the parts i need before i start building.Does anyone know what size sproket i should use on the axle i will be running a 1:1 ratio to the peerless 700 and the gear box has a 8 tooth sprocket. Im wanting to go around 20mph
This might help A CHARTBut it doesnt have 8 tooth.. | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5231 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: mud monster November 21st 2012, 2:04 pm | |
| Check this out http://www.rbracing-rsr.com/gearspeed.htmlIts set up for bikes, but just entering "1" for all the gear ratios, and primary and secondary sprockets it will help you figure out top speed. If you have a geared transmission and know the ratios it will tell you speed in each gear. | |
greener179 Member
| Subject: Re: mud monster November 21st 2012, 3:34 pm | |
| im not smart enough to use that calculater | |
| Subject: It takes a bit of time to figure it out November 21st 2012, 3:47 pm | |
| - greener179 wrote:
- im not smart enough to use that calculater
Dont be upset, It took me a few to figure out.. Ill help you if you want..? | |
greener179 Member
| Subject: Re: mud monster November 21st 2012, 7:01 pm | |
| if you could help it will be greatly appreciated any info you need to know i will be on till 1am or so | |
| Subject: engine size November 21st 2012, 7:12 pm | |
| - greener179 wrote:
- if you could help it will be greatly appreciated any info you need to know i will be on till 1am or so
What is your engine size and brand? or throw me a model number What is your front gear sproket teeth #? And what is the one on the axle? and you said your pulleys are going to be 1:1 right? and no jack shaft? so that is 1:1 All you need now is the size of your tire...and to get that you need to measure the circumference ( all the way around) | |
| Subject: Re: mud monster November 21st 2012, 7:35 pm | |
All you need now is the size of your tire...and to get that you need to measure the circumference ( all the way around) actually the formula calls for the diameter of the rear tire. Jack up the tractor, and measure the tire form the bottom to top. Use that number in the equation. Circumfrence is the diameter x 3.1416 (pi) The software is merely a script that does a mathematical calculation. If you don't know what it is, and just need a basic number to work off of, then enter 1 for anything you don't know. Growth rate is dependent on the tire you have . Turf tires won't grow enough to be worried about. ATV tires will grow in diameter (circumfrence as well) as the speed increases and centrifugal force stretches the tire. Calculate at 1.15 for atv tires, 1 for turf/AG tires
Last edited by Chopperhed on November 21st 2012, 7:50 pm; edited 1 time in total | |
greener179 Member
| Subject: Re: mud monster November 21st 2012, 7:37 pm | |
| i got a 12hp power built flat head dont know modle number its dark outside,the sprocket on the gearbox is 8 tooth and the axle will be 60 or what ever size sprocket i could get 20 25 mph with,the tires are 27 inches | |
| Subject: If i did this right November 21st 2012, 7:46 pm | |
| - greener179 wrote:
- i got a 12hp power built flat head dont know modle number its dark outside,the sprocket on the gearbox is 8 tooth and the axle will be 60 or what ever size sprocket i could get 20 25 mph with,the tires are 27 inches
If I did it right, you would be looking at 24mph @ 2300rpm and 40.5mph@3800RPM I dont know what your engine has for RPMs..so I did both...this is also taking into account the calculator works for this application..and if Im doing it right.. | |
| Subject: Re: mud monster November 21st 2012, 7:53 pm | |
| For the above equation to be right you would have to assume the transaxle is a 1:1 ratio in high gear.
greener179 Member
| Subject: Re: mud monster November 21st 2012, 7:57 pm | |
| i hate figuring out speeds so im going to wing it and put a 60 tooth on the axle and thanks junkstartbuilds,copperhead | |
| mud monster | |
