| Monster Mud mower | |
+6DICE464 Ford Boi Trcustoms dangeroustoys56 Chunk redzz02 10 posters |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 29 Join date : 2010-05-12 Points : 6342 Posts : 899 Location : PA pittsburgh and pymatuning
| Subject: Monster Mud mower September 26th 2010, 7:02 pm | |
| i have one monster mower but the chain kept popping and decided to make it a road mower but i finally fixed the chain situation this weekend but i already started to make this one plus my friend has 2 so i gotta have two lol, after mudding and my friend having complications with his mower he decided to sell it to me for 25$ thats what it looked like when i first got it it has a 15.5 ohv(hate ohv's) this is what it looked like at my house with a new hood then here starts the mods thats the front axle and the second to last pic shows the amount of flex it will have, i am also putting shocks onto it 6 spd tranny hope the 6 spd lasts me because this is the one bushing on the shaft and i couldnt replace it so it wiggles around alot the back end the pulley still needs done, fully welded and rienforcements | |
Guest Guest
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 26th 2010, 9:52 pm | |
| hope to have it done for this weeknd and i took my black one on the way home behind jims and didnt pop once | |
Guest Guest
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 27th 2010, 4:46 pm | |
| no i didnt i didnt have enough time but im taking it in the swamp this weekend, but im ordering a shaft and bearing to raise up the pulley tonight | |
Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6186 Posts : 779 Location : Angus, Scotland
| Subject: Re: Monster Mud mower September 27th 2010, 5:18 pm | |
| How'd you get that needle bearing out out of interest? Nice to finally see a build thread of a monster mower, see how its done first hand! | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 27th 2010, 5:36 pm | |
| sorry that picture is so bad its actualy one of the brass bushings from shaft right next to the brake disc thats why i couldnt replace it because of the disc not coming off | |
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
| Subject: Re: Monster Mud mower September 27th 2010, 5:41 pm | |
| Chunk: You could use a square pillow block bering - only real issue id see is getting the extended input shaft straight ( no wobbling). For best results id use two berings - one near the bottom- one near the top. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 27th 2010, 6:43 pm | |
| when i get the parts i need i am doing basicaly your idea just its hard to explain how im doing it so when i do get the parts i will take pics and explain with them aslo chunk i already had a monster mower build but i cant remember if it was that detailed or not | |
| Subject: Re: Monster Mud mower September 28th 2010, 3:34 pm | |
| Its just more for the fact the input shaft on my lawn mowing tractor has eaten into the tranny case! Can get away with fitting a new bushing or something, just not sure where to get one. | |
| Subject: Re: Monster Mud mower September 28th 2010, 3:41 pm | |
| Since its done that- id match one up at the auto parts store - large enough for the input shaft, small enough for the case. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 28th 2010, 7:37 pm | |
| yea im not sure about that one but i would try and get one thatl work for it now | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 28th 2010, 7:47 pm | |
| i got somemore work done got it sitting on all fours but remember its gonna have 23's in the back and 20's in the front not no dinky tires hole cut in the hood for the exhaust a picture of part of the exhaust done camo green paint i have a cool idea for the paint job | |
| Subject: Re: Monster Mud mower September 29th 2010, 7:49 am | |
| That exhaust looks good like. Thouht for a second there that paint sprayed out a camo pattern! | |
Trcustoms Member
Join date : 2010-09-19 Points : 5375 Posts : 225 Location : Bear,De USA
| Subject: Re: Monster Mud mower September 29th 2010, 9:55 am | |
| Awesome, isn't the exhaust going to blow in your face though? The camo paint will be cool. What size angle steel did you use and what gauge? | |
Ford Boi Member
Age : 40 Join date : 2010-08-22 Points : 5434 Posts : 242 Location : Yarmouth, Nova Scotia, Canada
| Subject: Re: Monster Mud mower September 29th 2010, 4:53 pm | |
| How do you have the engine and exhaust setup up in there? Btw looks dinky with the stock tires can't wait to see the big tires!! | |
| Subject: Re: Monster Mud mower September 29th 2010, 6:04 pm | |
| Looks pretty cool- imagine a set of 5 bolt rear tires off a craftsman GT on it.... | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 29th 2010, 6:11 pm | |
| 1. im putting a flapper on it so it will help a little from it hitting me in the face 2. its 1/8th inch thick and how ever wide a regular craftsman front axle is and CHUNK lol i thought it sprayed camo out awhile ago but then realized its just used for camo but heres some pics of the paint not done yet tell me what you think and im dieing to put the bigger tires on it looks so dinky and stupid with these tires on it | |
Guest Guest
Ford Boi Member
| Subject: Re: Monster Mud mower September 29th 2010, 8:43 pm | |
| LOVING THE PAINT DUDE!!!!! Totally military look. That's gotta be one of the toughest looking paintjobs I've seen. | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower September 30th 2010, 5:55 pm | |
| k guys heres how im doing the rearend first i took two old big pulleys and cut out the centers, then i slid the centers onto a 5/8 shaft and welded all around this will act as a cupling for the input shaft and 5/8 shaft extension then i got a jackshaft bearing or you could use a pillowblock bearing i welded the bearing mount to a solid brace to keep the shaft from moving back and forth, this suports the shaft and will keep it from ripping out your input shaft this is it all together you just add keys, set screws and a pulley on top with a little snap ring grove to hold it all on and heres some pics in the light still needs more work paint, welding, and still doesnt move | |
Trcustoms Member
| Subject: Re: Monster Mud mower September 30th 2010, 10:37 pm | |
| And all the stock steering linkages still work fine? | |
Trcustoms Member
| Subject: Re: Monster Mud mower September 30th 2010, 10:40 pm | |
| I was looking at your pics again and i spotted a yellow vintage briggs. What model and year? Go to the engine tech section and check out a vid of my 1949 5s if you have the time. | |
Ford Boi Member
| Subject: Re: Monster Mud mower October 1st 2010, 12:24 am | |
| That beast is looking awesome, like the shaft idea, but I have 2 concerns. 1: keeping those set screws tight and 2: that mild steel rod as a shaft. I can't say for sure but I think an old axle would probly be stronger? Hope your setup works tho. You've definitely put alot of work into it and I hope it works well! I have thought about a setup like that, but I was thinking about using a small U-joint (from a steering shaft of a car) in there somewhere to keep it turning smooth. Just throwin out some Ideas don't hate lol. I'm going to have to start building a monster as well, I will accept any and all criticism from you gratefully lol !
Ford Boi Member
| Subject: Re: Monster Mud mower October 1st 2010, 12:30 am | |
| - Trcustoms wrote:
- I was looking at your pics again and i spotted a yellow vintage briggs.
What model and year? Go to the engine tech section and check out a vid of my 1949 5s if you have the time. I've got a very good running 1966 2 1/4 HP Briggs horizontal shaft! out of a power trowel made by Master Vibrator LOL , got the motor for free, put n a pedal bike. I'll post up pics when I find 'em ! | |
