| Monster Mud mower | |
+6DICE464 Ford Boi Trcustoms dangeroustoys56 Chunk redzz02 10 posters |
| Subject: Re: Monster Mud mower February 20th 2011, 9:03 pm | |
| Couple years ago in the swamp behind the folks place i burried my agway- the thick gooey muck mud ( its a heavy black soil that area farmers grow potatoes in) was too much for the stock tires on it after churning it up the day before .
Sunk right down to the footrests - i had to hop off and push it out- if i didnt have the stock motor pulley on and most the deck hardware on it- it mightve been easier to get it out. | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
| Subject: Re: Monster Mud mower February 21st 2011, 8:11 pm | |
| yes yes, we have had more than our fair share of burrying our mowers up to the pack fenders in thick greesy mud and in the swampy never ending mud they arent fun to get unstuck, i personaly like the deep water wholes rather than the deep thick mud holes it sucks getting realy stuck and taking hours to get out of it | |
fetters18 Member
Age : 27 Join date : 2010-12-18 Points : 5160 Posts : 59 Location : ohio
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 21st 2011, 8:24 pm | |
| eventualy it will specially when its not sealed and the one bushing is rotted out like mine is, but if you seal the tranny and put some gear oil in it theres no need to worry | |
fetters18 Member
| Subject: mud mower February 21st 2011, 9:59 pm | |
| ok thanks ! becauce im building one ! | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 21st 2011, 10:11 pm | |
| no problem so far i havent had any problems with water ruining the tranny, just beating them too hard and breaking and cracking them so you should be fine all the trannys ive had that ive popped open are full of mud greese, and water and they still work good | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 21st 2011, 10:14 pm | |
| and if you have any questions about the build i could answer them | |
fetters18 Member
| Subject: monster mud mower February 22nd 2011, 9:10 pm | |
| how did u do it shifter for it
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 22nd 2011, 10:38 pm | |
| i cut the original shifter at the kidpoint of it and welded a piece of rod into it to etend it, but it is hadr to shift so if i was you, i assume you are using a craftsman? unbolt the plate that has the shift pattern on it and move it as far forward and redrill the holes and bolt it back down. this will give you more of an angle for the shifter and will be easier to shift | |
fetters18 Member
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 23rd 2011, 3:39 pm | |
| on my black one? yes its strong but pointer for that one weld you brackets for the traction bars as low on the axle as posible or when you go into a ditch the front axle will roll and break your shocks then you screwed and need towed home | |
redzz02 Site VIP
| ill make an explaination video of how i built it later on today or tomarow for you | |
fetters18 Member
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 23rd 2011, 7:00 pm | |
| as for the reasons i built mine haha, but honestly i think you should just drop down the front axle, no matter what im still gonna make the video for you but the suspension on my black on really doesnt work, it gives you a softer and bouncier ride and helps some but dont expect it to work like a truck or atv i will explain the reasons in the video i make | |
fetters18 Member
| Subject: Re: Monster Mud mower February 23rd 2011, 7:27 pm | |
| ya but i dont have a welder and i think it would be eaiser to do the shocks but if i have to weld i have to take it to my dads work haha | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 23rd 2011, 7:29 pm | |
| either way your gonna have to weld, but with the shocks you weld less | |
fetters18 Member
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 23rd 2011, 7:40 pm | |
| alright, ill try and get that vid up for you tomarow night | |
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 24th 2011, 3:33 pm | |
| im uploading the video right now,its 3:33pm but hope it helps | |
fetters18 Member
redzz02 Site VIP
| Subject: Re: Monster Mud mower February 24th 2011, 8:23 pm | |
| glad to help, if you need anything explained more i can its hard to explain stuff while holding a video camera like mine where it needs to be far back to see something close | |
fetters18 Member
| Subject: Re: Monster Mud mower February 25th 2011, 3:00 pm | |
| i have 5 1/2 ft of angle iron and about 30 ft or more of round pipe what will woork better ?? | |
Lawn Boy New Member
Age : 25 Join date : 2013-12-01 Points : 4012 Posts : 4 Location : Missouri
Lawn Boy New Member
richie thomas Veteran Member
| Subject: Re: Monster Mud mower January 19th 2014, 8:58 pm | |
| just wondering, why are you posting this in a old thread that aint been active in a couple years?
