 Small lift
2 posters
Caleb10123
Caleb10123
Small lift Empty
PostSubject: Small lift   Small lift Icon_minitimeSeptember 26th 2013, 2:18 pm
ive searched the build threads and cant seem to find someone who has done a small lift. like 3-6 inches. everyones done these 12 inch and plus lifts, i just want something to clear tires and give it tthe look of some modification done to the green machine. anybody on here done in between 3 to 6 inches? if so share some pics and how you did it. apperciate it!
BlackMountian88
BlackMountian88
Small lift Empty
PostSubject: Re: Small lift   Small lift Icon_minitimeSeptember 26th 2013, 2:46 pm
I did that.
What I did, was just buy longer bolts, and put about 3" of rubber between the frame and transaxle. The thing is, DONT use rubber. It flexes too much. Razz
And then I just ran the belt off the mower deck spindle, so I got a free pulley swap too!
I did leave the front stock tho.
Hope that helped!
Caleb10123
Caleb10123
Small lift Empty
PostSubject: Re: Small lift   Small lift Icon_minitimeSeptember 26th 2013, 6:33 pm
what should i properly use and how did you run the clutch setup? if you lift the tranny from the frame itll mis align the pulleys?
Small lift Empty
Small lift
» A Basic but Strong Lift, for Your Tractor (based on a homebuilt subaru lift).
» How do you lift mower????????
» How do I lift a Craftsman?
» Lift on the mower
» How to lift my tractor
