my plan is to have an all around trail mower, mud mower.
this is how it sits now. it has a 4-5in pulleys and does about 15-20 with 23's and a locked 6 spd. i am having tranny troubles but its just the shift pins and it pops in and out of gear because of it. my plans are to atv rack, 25's, snorkel, skid plate, winch, and some other goodies, youlll just have to wait and see. ill get videos up on my youtube Redzz02 ill get one up of how it is now and then ill start building it up
haha yea it does rub, and yes i am making a new exhaust especialy with the tires i put on it today it will rub almost on flat ground tire on the right is an 18 inch tire, they are going on the front
custom fenders for the rear rack to be easily mounted
rear rack modified some
rack support
cut my finger with a hacksaw making the back handle for the rack
steering stops to fit the 18inch tires
tranny cracked open to fix it, you can see the one shift key is snapped in half. i bent the one that was inside of the tranny and i went to bend the second key and snapped in half so i cant get it moving until i find another key
nah sadly i didnt get any video. it was a spur of the moment thing and i didnt have any batteries for the camera. and its a creek running throught the woods, ill get some more pics and ill take videos when i go back down. i need to finish the brakes on my mower.... it was scary going up some of the hills i went up with that mower, i need to make sure i can stop lol
fetters18 Member
Age : 27 Join date : 2010-12-18 Points : 5160 Posts : 59 Location : ohio
its a little cold and i probably shouldnt have taken the tape off but im gonna get some 2000 grit sand paper from school and sand the little dust particles off it before i spray clear over it,
and logan its about 10 minutes from my house down here in pittsburgh
arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5810 Posts : 320 Location : Canada, BC
ebay i have them on alot of my mowers, they have them for anything you could imahine on ebay, tools, beer, dirtbike, truck, car, quads lol alot of things it says warning tampering with my lawn mower may result in an ass whoopin youll necer for get and thers a pic of a tractor and a guy with a baseball vat smacking somone
MSteele323 Member
Age : 50 Join date : 2010-04-09 Points : 5701 Posts : 267 Location : Little Rock Arkansas
well once again the video camera i bought off a friend for 10$ failed me i took videos of me going through mud pits and riding this trail, but when i got home there were no videos there so i only have these three picts of it after wards
but actualy i have one video from after i was done riding and ill upload it to youtube for you guys
MSteele323 Member
hey guys im sorry for the lack of videos like usual i need a new camera!!!!!! but just an update. my locker broke and now i dont have posi anymore. i knew my welds were gonna brake. but its still moving. but i cracked the casing of the tranny when i went to take it apart to look at my locker..... DONT USE ENGINE GASKET SEALER TO SEAL YOUR TRANNY!!!!!!!!!!!!!!!!!!!!!! UNLESSS YOU NEVER WANT IT TO COME APART LOL. so now im runnning the tranny till she brakes and building up a 4spd. heres a video of me trying to climb this creek. i did it with my locker in like 7 times and i did it once after the video is over.
Should try letting some air out of the tires - that would give you better traction. Bring along a lil 12volt air pump to air em up for traveling.
I picked up one of those ' slime ' repair kits for under $15 years ago - it came with a small air compressor- its not enough to pop beads back on, but enough to put air in.
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
You can pop the beads back on using that compressor and a hand held sledge hammer. While you have the air going to the tire, hit the on the tread and usually you can get the bead to set.
arild365 Member
ive tried that and they usually dont pump enough air fast enough to pop the bead back on. the only way ive had it work with those small compressors is to use a rathet strap and tightening it around the tire and... yah but they are nice to just have on the trails
Jamus Established Member
Age : 45 Join date : 2010-06-28 Points : 5803 Posts : 511 Location : Southern WV
