 BIG Nasty - 1971 Rokon RT140 1wd Trailbraker
Hillbilly Offroading
2019 Build-Off Entrant
1st Place Build-Off 2020
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker Empty
PostSubject: BIG Nasty - 1971 Rokon RT140 1wd Trailbraker   BIG Nasty - 1971 Rokon RT140 1wd Trailbraker Icon_minitimeOctober 5th 2020, 5:25 pm
Newest edition to the family... Big Nasty! Something about them name is jump out at me about the vibe on this little tank. Not sure if it would fall under as a mini bike since its 6'5" long and 44" high but its a bike. I believe its a '71 Rokon RT140 1wd. Made from '70-'73. This could get interesting. Shes got them 60s 23x8.50x12 grooved vtread look to her. Those tires are so dry rotted but they held air well at least until I sat on it. The side walls opened up and air left. So it had a little 140cc tecumseh flathead from the factory. I found a engine in my scrap pile I had for gotten about. Its a Honda GX240-242 8hp. 102cc more with over head values. Came off a old mortar mixer. She should rip. Had to remove a good bit off the motor to get it some what closer to fitting in the frame. Theres alot more chopping to the frame ill need to do to make it fix but should be sweet. It will need new exhaust, carb with filter setup, and gas tank relocated.
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201017
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201019
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201018
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201022
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201020
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201021
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201025
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201024
BIG Nasty - 1971 Rokon RT140 1wd Trailbraker 20201023
» Redline's 1971 Ford F-100 Big Block swb
» 1971-1974 Terrajet 400e 4x4
» 1971 Struck corp MD1200 mini dozer
» Howdy from the nasty nati!
» 'Nasty Ferguson' new build thread!
