| mst-205 and 930-011 questions | |
steelheadben New Member
| Subject: mst-205 and 930-011 questions October 16th 2019, 8:50 am | |
| I recently picked up a locked mst-205 transaxle with brand new mud tires on it. My current lawn tractor has a peerless 930-011 6-speed transaxle. I was wondering if the "locker" setup internally in the mst-205 would completely swap over to the 930-011 transaxle. trying to avoid making a custom shift linkage for the mst-205 if i were to install the whole transaxle instead. | |
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 9:08 am | |
| Both transaxles have an open diff, but yes it will all swap over. The only possible difference would be the shift shaft height. Murray seems to like tall ones, everyone else uses short shafts flush with the top of the case | |
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 9:44 am | |
| - CraftsmanQuad19 wrote:
- Both transaxles have an open diff, but yes it will all swap over. The only possible difference would be the shift shaft height. Murray seems to like tall ones, everyone else uses short shafts flush with the top of the case
what will swap over.. the internal parts in each or installing the whole mst-205 transaxle on the tractor? | |
| | | | AllisKidD21 Moderator
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 10:40 am | |
| I think he's just looking to swap the differential assembly though. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 11:00 am | |
| - AllisKidD21 wrote:
- I think he's just looking to swap the differential assembly though.
Correct, was wondering if the differential assembly swaps over. | |
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 11:23 am | |
| I believe the spider gears and ring gear are the same in both models, but I haven't really messed around with those style transaxles very much so I can't say for certain. If you feel like it you could open them both up and just try the fitment, then you would know for sure. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 12:29 pm | |
- I believe the spider gears and ring gear are the same in both models, but I haven't really messed around with those style transaxles very much so I can't say for certain. If you feel like it you could open them both up and just try the fitment, then you would know for sure.
Thank you for your input. I was hoping to know for sure before splitting both cases but it looks like I might as well split them and check them out | |
| | | mowerjunkie03 Member
Age : 20 Join date : 2018-10-29 Points : 2593 Posts : 342 Location : Burnt Ranch, California
| Subject: Re: mst-205 and 930-011 questions October 16th 2019, 6:02 pm | |
| Wait. Hold up. Don't MSTs have taller, skinnier ring gears and 5/8 cross pins instead 1/2 like the 900 series? | |
| Who is online? | In total there are 44 users online :: 0 Registered, 0 Hidden and 44 Guests
