| Questions on exhaust. | |
Nathan43 Member
Age : 28 Join date : 2013-03-17 Points : 4311 Posts : 33 Location : Natchitoches, Louisiana
| Subject: Questions on exhaust. April 26th 2013, 12:36 pm | |
| I got a free mower the other day that didn't a header or muffler and i need to build some kind of exhaust for it. I'm not to worried about looks, but I am on things like back pressure, performance and valves. Can someone clear some light on the subject.
My dad thought stacks would be cool. | |
Nathan43 Member
| Subject: Re: Questions on exhaust. April 26th 2013, 12:41 pm | |
| O and if it helps, the engine is a 12.5hp 1995 Briggs and Stratton with both a (I believe) 1" thread and flange exhaust mount. | |
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5248 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
| Subject: Re: Questions on exhaust. April 26th 2013, 12:47 pm | |
| The simplest way would be to build one out of 1" pipe.
a couple of elbows should give enough backpressure.
It will need to be supported to avoid broken threads or cracked cylinder head. | |
Nathan43 Member
truckin42 Veteran Member
Age : 26 Join date : 2012-10-04 Points : 5497 Posts : 1070
| Subject: Re: Questions on exhaust. April 26th 2013, 4:28 pm | |
| - Nathan43 wrote:
- Can I use about two 90 degree or two 45s.
Which ever ones you like. Adding more bends equals more back pressure and a bit quieter noise | |
Nathan43 Member
| Subject: Re: Questions on exhaust. April 26th 2013, 8:36 pm | |
| This might seem stupid but can i put a mufler about halfway up the stack so it isnt that loud. (neighbors )If it would work i have either a push mower mufler and a 20hp koler mufler. Note: This is going on a 12.5 horespower flathead briggs. | |
Age : 27 Join date : 2013-03-18 Points : 7477 Posts : 3131 Location : raleigh nc
| Subject: Re: Questions on exhaust. April 26th 2013, 8:39 pm | |
| - Nathan43 wrote:
- This might seem stupid but can i put a mufler about halfway up the stack so it isnt that loud. (neighbors )If it would work i have either a push mower mufler and a 20hp koler mufler. Note: This is going on a 12.5 horespower flathead briggs.
I have the same motor. do you have the same mower as me? | |
Nathan43 Member
| Subject: Re: Questions on exhaust. April 26th 2013, 8:44 pm | |
| Doubt it I have a 95 Wizard. I believe it is just a renamed mower made by a bigger company. I'll post a few pics give me a min. | |
Nathan43 Member
| Subject: Re: Questions on exhaust. April 26th 2013, 9:00 pm | |
| [img] [/img] [img] [/img] [img] [/img] Here she is, my current project.Not the original seat or tires. Oh and I used fearless fronts wiring diagram for a briggs, how do i wire the headlights that's the only part I didn't understand. | |
| Subject: Re: Questions on exhaust. April 26th 2013, 9:20 pm | |
For a muffler use something wiyh at least (or bigger) inlet size as the pipe you are using for exhaust. Or you can buy a small tractor muffler and modify it to fit. | |
| Subject: Re: Questions on exhaust. April 26th 2013, 9:31 pm | |
| sweet pics man. And there shoulf be two wires and a plug that come out near the dipstick. that's how it is on mine, or was. I just plug in the lights, and the power goes to the bulbs, and then a ground wire is on the front of the motor. | |
Nathan43 Member
| Subject: Re: Questions on exhaust. April 26th 2013, 9:39 pm | |
| So I connect one wire from the lights to the side of the plug that does not have the diode and the other wire from the lights to a switch and then to a ground. Oh and thanks for the great help ill post a build topic one day. | |
| Subject: Re: Questions on exhaust. April 26th 2013, 9:49 pm | |
| yea no problameo. I took my lights off temporarily once. then I stepped on them ;-; | |
