 exhaust idea
Chopperhed
matthew sidor
theswampmachine
9 posters
theswampmachine
exhaust idea Empty
PostSubject: exhaust idea   exhaust idea Icon_minitimeJanuary 14th 2013, 12:50 pm
exhaust idea Photo10
Im looking for an idea for an exhaust for my tractor. I was thinking it would be cool to run it under the body and have it come out right before the rear tires so it would look like one of those old hot rods. what do you think? any other ideas of what i could do? The only thing i dont want is stacks.
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 14th 2013, 1:33 pm
That's similar to what my exhaust does, except mine come out about halfway down the foot boards... It is pretty loud, but sounds awesome Very Happy
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 14th 2013, 3:07 pm
Try something like this. exhaust idea Photo-22
matthew sidor
matthew sidor
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 14th 2013, 8:28 pm
Heres an easy way to make a muffler
exhaust idea 226762_458726224188812_566874203_n
Chopperhed
Chopperhed
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 14th 2013, 9:33 pm
Exhaust for threaded exhaust ports is simply a matter of threading together pieces of pipe.
If you dont have a threaded exhaust port. You can make yourself an exhaust flange and either weld a threaded nipple to it, or NEW IDEA JUST NOW,
Got to a home depot or equivalentand buy a 3/4" malleable iron floor flange. It doens't matter if the holes match, but you'll be able to cut it down and drill it to match your bolting.
Then you can use threaded pipe any way you want.
I cut a flange out of 3/8" plate, and welded a piece of Galvinized flex exhaust hose to it. Then went to a piece of 1" thin wall electrical conduit. (light and cheap)
Whole thing cost me six bucks.
theswampmachine
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 14th 2013, 11:34 pm
I like those exhaust but I don't care for that kind of pipe and I don't have threaded exhausts. I have the ability to bend pipe so it looks cleaner and flows better but thanks for the ideas if how you did yours. Have you guys ever had it break off through? That's one thing I worry about with it being under the mower. Also I worry about water gettig in there if I stall in deep water
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 15th 2013, 12:44 am
Best way to avoid it breaking off is to weld in a section of flex pipe near the motor and have the rest hang on rubber (or other type) flexible hangars, similar to a car setup. Another way would be to make sure that the pipe doesnt move at all when its on the frame (very strong brackets).
Water could be an issue with plugging the hole if it stalls. Thats why a lot of people prefer to run it high either under the running boards (like Ariens build) or high out by the rear fenders.
If you have it run out low, you could always thread the end of it and make an extra section for a snorkel kit addon if you ever do go into deep water.
lt1000
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 15th 2013, 8:43 am
i made a homemade flange and use 1 inch threaded to a briggs can muffler which fits 2 1/4 exhaust which is a 18 inch straight to a 45 with an angle cut but for some reason the spark arrestor on them can mufflers i keep blowing em out in high revs anyone no where i can get a high quality one?
thatrandomguy
thatrandomguy
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeJanuary 15th 2013, 12:48 pm
here's my 18 hp twin exhaust setup.
exhaust idea DSC09513_zps92743d0a
exhaust idea DSC09514_zps9c1f3cc8
exhaust idea DSC09516_zps87a30b53
here's a vid of it running:
https://www.youtube.com/watch?v=oIyNZlX8oFo
theswampmachine
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeFebruary 5th 2013, 10:54 am
[img]exhaust idea Image112[/img][img]exhaust idea Image212[/img][img]exhaust idea Image311[/img][img]exhaust idea Image411[/img][img]exhaust idea Image511[/img][img]exhaust idea Image612[/img]
This was the exhaust build i decided to do it has 2 round pipes going in to one large square pipe with 4 smaller square pipes coming out of it. I dont have a video of it running and i dont have any idea how it sounds yet. I also put 8 inch rims on the front along with some 18in tires. It now has 11inches of clearance in the front and sits just about level
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeFebruary 5th 2013, 11:02 am
Might want to add a drain plug at the bottom of that. Water will collect in bottom.
Chaos Build
Haspin 2021 thread
theswampmachine
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeFebruary 5th 2013, 11:04 am
already got it i have 2 small holes on each side of the square tube to train water.
CornishMorgan
exhaust idea Empty
PostSubject: Re: exhaust idea   exhaust idea Icon_minitimeFebruary 10th 2013, 9:39 am
haha that looks bad ass, I love it
exhaust idea Empty
exhaust idea
» whats the best idea for the exhaust
» Exhaust/Stack Ideas
» Tater's "OH Deere 116 dragster" [2017 Build-Off Entry]
» Exhaust Flanges
» Questions on exhaust.
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Exhaust-
