| Exhaust/Stack Ideas | |
+19Thecrazyoldcraftman Doug Junkstarbuilds Ariens YT11 boggo Tractor Man Jeff CornishMorgan TheRainbowBoxer gearheadmike W1ldyOvvnZ Craftsman Dude Chopperhed TennesseeCowboy Bigal CityRedneck AcreFarm canadianromper dangeroustoys56 Crazymudder 23 posters |
Crazymudder Member
Age : 111 Join date : 2011-03-30 Points : 5019 Posts : 31 Location : United States
| Subject: custom Exhaust for lawn tractor April 15th 2011, 9:53 pm | |
| I'm making a sweet exhaust what way is reccomeneded to sound good and still be fairly loud | |
| Subject: Re: Exhaust/Stack Ideas April 16th 2011, 7:36 am | |
| Well, it has to be long enough with some bends in it - otherwise youll be looking at burnt valves- motors like a lil back pressure.
Most people run thiers either stack style or straight out the back- i like the side pipe exit before the rear tires- old skool style. | |
Crazymudder Member
| Subject: Exhaust April 16th 2011, 6:26 pm | |
canadianromper Member
Age : 25 Join date : 2011-11-30 Points : 4857 Posts : 114 Location : ontario canada
| Subject: Re: Exhaust/Stack Ideas December 11th 2011, 3:44 pm | |
| i made mine go under me footrest and it sounds pretty good to me.I used to have a stack on it and i couldn`t get it to stay but it sounded really good | |
AcreFarm Member
Age : 40 Join date : 2011-11-02 Points : 4933 Posts : 208 Location : Tennessee
| Subject: Re: Exhaust/Stack Ideas December 11th 2011, 4:04 pm | |
| I ran mine under the footrest too, straight out to the back of the tractor. I stepped the pipe from 1" off the block to 1 1/4 then up to 2" It's pretty loud, but overall sound is very good. | |
CityRedneck Member
Age : 28 Join date : 2011-08-13 Points : 5141 Posts : 241 Location : Winter Park
| Subject: Re: Exhaust/Stack Ideas December 11th 2011, 7:14 pm | |
| on mine im going to do a tugboat exhaust setup. make 2"holes in the fender of the body (dual) and on the outside of the fender will be atv exhaust tips and on the inside will be atv pipes. i want my 21hp to sound like a brute force hauling ass down the road (srry for the language)
Bigal Member
Join date : 2012-02-04 Points : 4743 Posts : 56 Location : ME
TennesseeCowboy Member
Age : 29 Join date : 2012-08-05 Points : 4623 Posts : 124 Location : TEN-A-SAYY
| Subject: Exhaust/Stack Ideas December 13th 2012, 4:08 pm | |
| I need some ideas for a stack or pipe of some kind for my mower. I want it to look like a tractor stack but i don't know how to build it or attach it. Any ideas or info would help tons. Here's some pics of my setup Somehow i need to make it so where my steering rods won't hit it.. | |
Chopperhed Moderator
| Subject: Re: Exhaust/Stack Ideas December 13th 2012, 4:13 pm | |
| If its a threaded muffler, then simple plumbing pipe will work to build a stack, but you will want to support the vertical part some how.
If its like my B&S it has a flanged outlet, in which case you got some fabbing to do. | |
Craftsman Dude Member
Age : 29 Join date : 2012-09-08 Points : 4609 Posts : 145 Location : MS
| Subject: Re: Exhaust/Stack Ideas December 13th 2012, 5:01 pm | |
| If its threaded it should be either 3/4" NPT or 1" NPT. Either way all you need is a 4-6" nipple, elbow, and piece of pipe as long as you want the stack to be.
Build a bracket of some sort to support the vertical stack.
You can also by adapters, etc. if you want a bigger stack | |
W1ldyOvvnZ Member
Age : 28 Join date : 2011-12-06 Points : 5248 Posts : 499 Location : Winchester, ON, Canada
| Subject: Re: Exhaust/Stack Ideas December 13th 2012, 5:18 pm | |
| wouldn't it be a flange? the two bolts are there that look like they attach into the block. I dont know if it also has a threaded part too(I never manged to get those style ones off, I end up leaving them how they come). I would go to a local store that sells tractor parts and get a tractor flap in whatever side you want then get a pipe that will fit the flap and put a 90 degree bend in it and weld it to the existing flange from the muffler or weld it right to the muffler. | |
gearheadmike Member
Age : 34 Join date : 2011-11-18 Points : 5203 Posts : 392 Location : west chazy ny
| Subject: Re: Exhaust/Stack Ideas December 13th 2012, 7:34 pm | |
| if its anythng like all my B&S engine it has both thread hole and the to threaded bolt holes for the exhaust style he has on it now. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5698 Posts : 1091 Location : Galion, OH
| Subject: Re: Exhaust/Stack Ideas December 14th 2012, 9:38 am | |
| That's the same thing I've seen... exhaust port has both threaded opening and bolt holes. | |
CornishMorgan Member
| Subject: Re: Exhaust/Stack Ideas December 14th 2012, 12:50 pm | |
| My 11hp briggs flathead has a 1inch outlet port with a thread and bolt holes. The 2 bolts in the muffler go into the outlet ports to hold it in and there is a bolt in the head that supports the muffler. When i pulled my muffler there was no threads on the muffler, it was just bolted to the engine, the muffler didn't have a thread. I'd guess yours will be the same since we have the same engine. | |
| Subject: Re: Exhaust/Stack Ideas December 14th 2012, 7:22 pm | |
| Of all the briggs motors ive seen the flatheads had threads and th OHVs didnt. | |
| Subject: Re: Exhaust/Stack Ideas December 14th 2012, 11:00 pm | |
| I haven't had a chance to take it off and see if its threaded or not. I like the tractor flapper idea though, sounds great. Is there any problems that i could run up on by doing this though? Like something exploding because of too much pressure or anything?! | |
Guest Guest
| Subject: Re: Exhaust/Stack Ideas December 15th 2012, 7:33 am | |
| - TennesseeCowboy wrote:
- I haven't had a chance to take it off and see if its threaded or not. I like the tractor flapper idea though, sounds great. Is there any problems that i could run up on by doing this though? Like something exploding because of too much pressure or anything?!
In another group I'm in they put a pipe nipple in the threads and cut it flush with the flanged surface. Seems odd to me, but they say the single makes more horsepower that way. Then they put on a flanged bolted header pipe. I read B&S took a 5hp and tried to see what could be done with it, and the largest horsepower gain came fron taking off the thread-in muffler and using a header pipe! Don at G-Team Racing has a couple videos on hopping up the flathead engines that are well worth buying. Garry |
Tractor Man Jeff Moderator
Age : 29 Join date : 2012-06-26 Points : 5010 Posts : 492 Location : Back in the sticks of VA
| Subject: Re: Exhaust/Stack Ideas December 15th 2012, 9:24 am | |
| I had a stack on my tractor for a while, but it proved more of a nuisance for several reasons. The way I did it was run it through the hood using pipe fittings. | |
| Subject: Re: Exhaust/Stack Ideas December 15th 2012, 3:51 pm | |
| That does look like it would get in the way being through the hood like that. I'm wanting to run mine out and up next to the hood. Does it make a big difference in sound? | |
| Subject: Re: Exhaust/Stack Ideas December 15th 2012, 4:10 pm | |
| The one above was pretty quiet, being a very short exhaust. My hood just wasn't shaped for a stack. It will be much easier with your tractor. | |
| Subject: Re: Exhaust/Stack Ideas December 15th 2012, 5:08 pm | |
| Yeah i figured lol. I want it to sound more deep like a tractor, how would i do that? | |
| Subject: Re: Exhaust/Stack Ideas December 15th 2012, 8:35 pm | |
| You can do it like this. Slip a piece of exhaust over the muffler. Makes it much louder. another way is to make the stack taller with the muffler at the bottom of the stack. You can also just straight pipe it. Though I stuck this stack over the muffler, I never tried it. Looks a little silly. | |
| Subject: Re: Exhaust/Stack Ideas December 18th 2012, 2:07 pm | |
| Ok, so i took it off and found out that the engine part is threaded. And i found a piece of pipe that would thread into it. What should i do next? (Unless I should just leave it like this... ) Its pretty loud too, how would i make it have a deeper roar to it instead of a loud popping sound? | |
