 SQUARE STACK!!!!!
Ghyde97
Ghyde97
SQUARE STACK!!!!! Empty
PostSubject: SQUARE STACK!!!!!   SQUARE STACK!!!!! Icon_minitimeNovember 6th 2014, 8:59 am
For my stack I took the stock box I cut the j pipe off then I welded that to a piece of plumbing pipe then I cut that at 2 45's and welded that together then I took a piece of fence post and cut notches out of it with a angle grinder then I bent those around the plumbing pipe. Then I welded that all together. Finally for the tip I took two pieces of bed frame angle iron and welded then together the I welded every bit of it together and to top it all off I blued the steel with a torch to give it a sinister look. Just thought I would share since I think it's badass and might help someone else. SQUARE STACK!!!!! Image23
SQUARE STACK!!!!! Image24 Mad SQUARE STACK!!!!! Image25
PostSubject: Re: SQUARE STACK!!!!!   SQUARE STACK!!!!! Icon_minitimeNovember 7th 2014, 6:57 pm
Youll need some serious brackets for that so you dont break your engine from the stress.
Ghyde97
Ghyde97
PostSubject: Re: SQUARE STACK!!!!!   SQUARE STACK!!!!! Icon_minitimeNovember 7th 2014, 8:21 pm
I've got a pretty hefty tab on the bottom that I welded on that when I pul back and forth on the stack it shakes the whole mower so I feel pretty comfortable about it
PostSubject: Re: SQUARE STACK!!!!!   SQUARE STACK!!!!! Icon_minitimeNovember 8th 2014, 1:26 pm
Nice, let's hear it!
SQUARE STACK!!!!!
» What saw do I need to cut 1" square tubing?
» I’m in love with her (Square) body!
» STACK PIPE 11hp
» angled cut tip or flapper stack?
» Exhaust/Stack Ideas
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Exhaust-
