 What saw do I need to cut 1" square tubing?
MurrayMayhem
breadtrk
T-Dub13
Moose
partin_us_99
13 posters
partin_us_99
What saw do I need to cut 1" square tubing? Empty
PostSubject: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 17th 2014, 10:11 am
so im fixin to start on my monster mower build and im trying to figure out the cheapest and best way to cut say 1" square tubing.
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 17th 2014, 10:18 am
So... What's the point, here? You bought a HF saw? You WANT to buy one? Looking for reviews? A little more detail is in order here...
Moose
Moose
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 17th 2014, 10:20 am
depends if you want accurate cuts or just cut it and weld the difference theres 20$ angle grinders everywhere 4 1/2" blade will do ok or you could step up to a circular saw think they make blades for them and then the always useful chopsaw if you find a cheap miter saw can go that route too but chopsaws tend to work ok when in doubt craigslist!
partin_us_99
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 20th 2014, 8:05 am
Moose
Moose
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 20th 2014, 10:09 am
read the reviews: I was happy to see this thing when it came to the shop. I needed a cut off saw badly. The first problem came up was the weak vise, would not for s#'+. I use a vise clamp now. Then when fired up it wobbled all over the place getting up to speed and still shook while cutting angle iron. It's now bolted down to a heavy beach. The cut's are off because of the poor constuction of the hinge, too much end play thus making this saw unsafe for any average user without modifing it first to run right.
you may get a better one but you can still get it and fix whatever is sub par on it if the hinge for the cutting assembly is loose throw a washer between it and tighten it if the blade wobbles try another one you get what you pay for but you can always make it better with a little more money and a little time youd still pay less than they want for the high end models
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 20th 2014, 2:47 pm
Look around on eBay, usually you can find factory refurbished DeWALT 14in chopsaws for around $130.
1in square tubing though you could do with a grinder with a cut-off wheel (NOT A GRINDING WHEEL), a circular saw with a metal blade, or a chopsaw. Hell, even a manual hacksaw with a metal blade would work.
T-Dub13
T-Dub13
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 20th 2014, 8:18 pm
OK, so my post disappeared lol
Go to a hardware store and get one of these, or a few.  Put it in your circular saw and chop away.
And when it gets too small for the circular saw, you can put it in your angle grinder.
What saw do I need to cut 1" square tubing? DBD070125L01F_600x600
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 20th 2014, 9:02 pm
a 5 dollar hacksaw will do the trick
breadtrk
breadtrk
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 21st 2014, 2:17 pm
Every time, even in the middle of the woods.
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 21st 2014, 3:18 pm
i would not reccomend that. my Dewalt 11 amp grinder turns at about 13,xxx RPM. most circ saw wheels are rated around 8-9k. could possibly explode
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 21st 2014, 3:39 pm
yup bread, Big Difference between need and want. The hacksaw id all ya need, you may WANT a power saw of some sort.
It ain't hard for a person that likes to tinker to come up with a power hacksaw.... If ya google DIY hacksaw, you can find lots of 'em out there. Lets keep in mind that a hacksaw blade is cheaper by the dozen than even a single cutoff wheel. If ya want Fast cuts, use door hinges to rig up your angle grinder and cutoff wheel. If ya stumble across a big cutoff saw at a yard sale, great! if not, there's more than one way to skin a cat... and at the end of the day, the cat ain't happy, no matter how he got skinned.
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 21st 2014, 4:38 pm
I'm gonna go ahead and second that. Never exceed the rated RPM of an abrasive wheel. I'm not saying it's impossible, it depends on your equipment. I KNOW my angle grinder turns 11K, so I simply cannot and will not do that.
Speaking of angle grinders:
Awhile back, a buddy loaned me his 14" abrasive cutoff saw. I hated it. One, the kerf it cut was outrageous, as compared to the 3/32" thick cutoff wheels I use in my angel grinders. Two, on more cuts than not (notably bevel cuts) the angle was out. Now, before you say "hey, you gotta calibrate those!", I did. But on a 45° angle cut, the clamp was allowing the stock to slip slightly. Nothing I tried produced the kind of accuracy I was used to. And what am I used to? My little angle grinder. I simply mark my cuts with the appropriate tool, and cut by hand. Could be because I have been doing it for years, but my cuts are quite accurate. FWIW, my buddy's saw was a Milwaukee.
I recently picked up a cheapy 14" offbrand unit at a garage sale for all of about $10. I have not yet used it. Really, my purpose is quick, straight cuts. I will likely continue to do my miter cuts by hand...
T-Dub13
T-Dub13
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 1:02 pm
I've had no problem with exploding cutoff blades in my angle grinder, but for liability's sake, I will only recommend it to myself.  Laughing
The reason the 7" wheels are only rated for 8,450 is because of their large diameter. When they get smaller, they can handle higher RPM's. The surface speed of the cutting edge will be comparable. Wink
MurrayMayhem
MurrayMayhem
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 4:43 pm
Man you guys use some hi-tech stuff, I hacksaw, everything by hand, it has a really old rusty blade but that's how you build muscle.
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 6:19 pm
I won't argue any of that, but you KNOW how this stuff goes... Wink
Man- I'm 40 years old, and bust my @ss for a living. Don't need to "build muscle" trying to do my hobbies!
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 8:17 pm
i personally think you should use a dull razor blade to cut it...
partin_us_99
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 8:48 pm
lol I only have one use for a dull razor blade. And trust me its not for metal and can be considered inhumane.
TroyBilt Pony
TroyBilt Pony
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 8:51 pm
Don't cut youngen..
partin_us_99
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 8:53 pm
o its not used on myself. But used on mouthy folks lol
partin_us_99
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 8:54 pm
Fyi it says saw not "I need more smart ass remarks in my ***** filled day"
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 9:06 pm
Do you need a hug?
partin_us_99
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 9:10 pm
ur damn right I do lol
Doc Sprocket wrote:
Do you need a hug?
*Sends electronic hug through DVD ROM*
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 9:14 pm
Actually, a regular hacksaw isn't as bad as most people might think. Cuts reasonably quick as long as you keep a fresh blade on it.
Here's what I use for most stuff these days. We bought one new some years back and it has held up pretty good to some severe abuse. I like using the sawzall more than a cut off wheel/grinder (whatever it's called) since it makes a thinner cut and cuts a little quicker. If you try to cut too fast/push too hard on those abrasive wheels, they seem to overheat and wear down quick (or break apart if your really getting carried away). Also, you can cut wider stuff with these with the longer blade vs the cut off wheel which is only 2" or so depth (until it wears down). Anyway, you can get pretty thin blades for these also to make reasonably tight curves in sheel metal ect.
What saw do I need to cut 1" square tubing? Saw10
partin_us_99
PostSubject: Re: What saw do I need to cut 1" square tubing?   What saw do I need to cut 1" square tubing? Icon_minitimeFebruary 24th 2014, 9:47 pm
Ya after running through 5 cut off discs on my angle grinder installing my lift I'm kinda iffy on using it or a chop saw. They're fragile as heck and break at high speeds sending disc shrapnel everywhere. only down fall to a sawzall etc would be having to make an angle jig for any angled cuts I would need. Might even search craigslist for a wet chop saw idk
» Help identifying older square body Craftsman.
» SQUARE STACK!!!!!
» I’m in love with her (Square) body!
» Craftsman square body build
» Tech Tip: Stuck Square Plug
