 STACK PIPE 11hp
arild365
dagr8tim
gearheadmike
boggo
8 posters
boggo
boggo
STACK PIPE 11hp Empty
PostSubject: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 11th 2012, 9:32 pm
STACK PIPE 11hp 2012-02-11134845
gearheadmike
gearheadmike
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 11th 2012, 9:46 pm
Nice looks good,is it threadedin or flange and bolted to engine? might want to make a support bracket just to keep some strain off it. looks good tho
dagr8tim
dagr8tim
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 11th 2012, 10:36 pm
Do you need any kind of bracing to keep the pipe from damaging the exhaust port?
http://buckeyejeeps.com
arild365
arild365
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 11th 2012, 10:55 pm
Hey man nice stack. thinkin this might be in the wrong section Razz
boggo
boggo
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 11th 2012, 11:27 pm
thanks i used the thread in the block no flanges yet, i do have a bracket to hold the stack.
i wasnt quite sure where this post should go so i just put it in the chassis section Razz
here is a pic of the bracket. thanks for looking and hope this helps for people wanting ideas of a stack Smile
STACK PIPE 11hp 2012-02-12124012
gearheadmike
gearheadmike
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 12th 2012, 9:38 am
looks good, just a ? how does that come off looks like it would have to be cut
dagr8tim
dagr8tim
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 12th 2012, 10:07 am
It does look good. I always wanted to have a small glass pack and use it as a resonator on a stack.
Bigal
Bigal
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 12th 2012, 3:56 pm
I have a stack on mine that you can see from my avatar mine is screwed into the engine block and were the bend in the pipe is i had to expend and contrast it so they would fit so now when i need to take of the pipe it just slides of very nicely
Mr&Mrs.Reckson
Mr&Mrs.Reckson
PostSubject: stack pipe 11hp   STACK PIPE 11hp Icon_minitimeFebruary 12th 2012, 10:52 pm
that is one of the best ideas ive used and scene now just use an old radiator hose and fit it in the carb and use some rtv sealant and a atv air filter check out batman010208s same engine before it had problems sow its a 17.5 b&s lol!
boggo
boggo
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeFebruary 13th 2012, 4:42 am
you can take the long part off the corner it just screws off i used a pipe fitting because the top pipe has thread on the bottom so it comes apart nicely so no cutting required
zmann422
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeApril 14th 2014, 1:44 pm
NICE!
PostSubject: Re: STACK PIPE 11hp   STACK PIPE 11hp Icon_minitimeApril 14th 2014, 1:53 pm
this topic has not been touched in 2 years. please do not dig up old, "dead" threads like this
STACK PIPE 11hp
» Pipe bending.
» Is my straight pipe the problem?
» New side pipe on my Murray select
» Exhaust/Stack Ideas
» SQUARE STACK!!!!!
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Exhaust-
