 angled cut tip or flapper stack?
2 posters
gilsonrumbler
gilsonrumbler
angled cut tip or flapper stack? Empty
PostSubject: angled cut tip or flapper stack?   angled cut tip or flapper stack? Icon_minitimeDecember 9th 2011, 6:28 pm
angled cut tip or flapper stack? 2vaf2ig
angled tip like that^ or chop the top flat and put a flapper on it? i actually like both but stuck on which one fits the mower better. yes that tip is actually in the hood not sitting there for looks
PostSubject: angled cut tip or flapper stack?   angled cut tip or flapper stack? Icon_minitimeDecember 9th 2011, 10:09 pm
one is just as good as the other. the angle cut wont keep water out if you park it outside in the rain. just remember to put a soup can on it ,or your valve stems will get rusty. worst case, you can hydro lock the motor if it gets enough water in it.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: angled cut tip or flapper stack?   angled cut tip or flapper stack? Icon_minitimeDecember 9th 2011, 11:41 pm
I personally would go with the flat top and a flapper because of what rat88 said but I like the look of the angle cut!
http://www.stat10.tk/
gilsonrumbler
gilsonrumbler
PostSubject: Re: angled cut tip or flapper stack?   angled cut tip or flapper stack? Icon_minitimeDecember 10th 2011, 12:37 am
tractor sits in a barn/shed if it did get water in it i wouldn't have a problem tearing motor down to clean it out.
» SQUARE STACK!!!!!
» Dually Murray with 16 horse techumseh
» STACK PIPE 11hp
» Exhaust/Stack Ideas
» Stack Idea for diesels?
All-Terrain Lawn Tractor Forum :: General Tractor Talk + Pictures/ Videos :: Pics and Videos-
