 Troy built big red help
5 posters
Kyracer13
Troy built big red help Empty
PostSubject: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 6:32 pm
Ok I have a old troy built big red horse with a 21hp brigss it's a good mower just slow as all get out what would be the best way to speed this thing up a little not looking for no 30 mph but if I could get maybe 10 mph out of it when it's in high be great
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 6:55 pm
Do you have an idea what the drivetrain setup is like? Some pictures of the machine might be helpful.
If it's just a standard belt and geared transaxle setup then it's pretty straight forward, but if it's a hydro or shaft driven trans it might be a little more difficult.
Kyracer13
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 7:04 pm
It's a standard belt drive has a 3 speed rear 2h,2low,reverse I'll try to get some pics when it stop raining
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 8:21 pm
This sounds interesting. I've never seen a Troy Bilt that wasn't hydro or varidrive. hmm
Troy built big red help Sig115PROJECTS:
Troy built big red help Sig214Troy built big red help Sig314
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 8:32 pm
Interesting, kinda sounds like a Wheel Horse by the description of the drivetrain setup.
Colour me intrigued!
Kyracer13
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 8:36 pm
[img]Troy built big red help 20190715_192801_zpsqymbt1ln[/img]
[img]Troy built big red help 20190715_192809_zpsmbf8xiqe[/img]
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 10:53 pm
AH, varidrive. It can be sped up, just a bit trickier than a standard gear driven trans.
Kyracer13
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 15th 2019, 11:08 pm
How would one go about speeding it up
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 16th 2019, 12:16 am
I will let those that have done it chime in as I have not increased speed on a varidrive. A couple places I would look...
Do you plan to continue mowing? If so, then pretty much need to stay away from the engine pulley. If not, then you can put a bigger pulley on.
Here is where it gets tricky due to varidrive design. You can go a smaller pulley on the input of the transaxle, but you would need to find a smaller belt for that part. Also, you would be reducing the amount of surface on that belt system causing it to slip a lot easier.
Like I said, I have not tackled a varidrive system yet and I could be thinking wrong.
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 16th 2019, 12:32 am
I had an old craftsman with one of those vari-drive deals. It burned up a couple belts and I wasn't even off roading it. Just mowing. I would set it and then try not to change the speed. That seemed to help. Maybe we had the wrong belt on it or something, but mostly I guess people don't like them that much. The idea is the same as a torque converter that you adjust manually. Snowmobiles use that setup pretty much and don't have a problem. But for some reason they're not that great on tractors. At least not the design they came up with.
If you were going to just play around with it and not mow, I would say put some big tires on the rear. That would increase the gearing a little bit. But that would mess up the height of the deck and also, bigger tires might not fit with the deck on anyway. So, I guess some sort of pulley swap might help. But as mightraze said, there might be some issues.
Search for posts/topics about vari-drive on the forum. I think there have been a few in the past.
Kyracer13
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 16th 2019, 8:11 am
I have a few engine pulleys could weld something up were the deck use same pully but the drive train used different size pully on the engine do any of yall see a issue here
PostSubject: Re: Troy built big red help   Troy built big red help Icon_minitimeJuly 16th 2019, 10:42 am
If I were you, I'd try to put on a transaxle pulley that's 2" smaller than the original, look up your rear drive belt part #, find out the size, and go get one 2" smaller than the old one at your auto parts store. If you have Carquest in your town then that would be the place to get your belt.
» troy built 4X6 flatbed ratrod
» Troy Built Mud Mower 708cc Predator V-Twin
» Anyone ever built one of these?
» first built but not the last
» Troy Bilt 3214HRS help.
